Question about Dell Inspiron 1525 Laptop
Canoscan LiDE 100 on WinXP loaded drivers+software from disk
When I plug scanner in all I get is USB device not recognised. Tried all ports. Tried a new lead, as Lide 100 is powered by USB lead. No joy. HELP!
    Scholar:
  • 154 Answers
Install the device driver before you plug in the scanner if that does nothing then update the drivers for your laptops chipset and USB this fixes this problem most of the time, if its doesnt try the following:
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2.
Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
Failing all of that LOOK HERE
Hope this helps you, thanks for using fixya.
Posted on Jul 05, 2010
    Master:
  • 497 Answers
Have you tried going to the Devices Website for any CURRENT SOFTWARE UPDATES/DOWNLOADS?
I connected canoscan lide 100 scanner but scan unit is not moving & Bulb also is not glowing
Make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
hope this helps
http://download.cnet.com/canoscan-lide-100/3000-2110_4-205353.html
http://download.cnet.com/canoscan-lide-100/3000-2110_4-205354.html
Apr 18, 2012 | Canon CanoScan LiDE 100
When i install canoscan lide 25 flatbed scanner i try to start my xp computer back up and it takes up to 5 minuets
Those 5 minutes are (1) WinXP trying (and failing) to locate the driver for your Canoscan flatbed scanner, or (2) WinXP perceives that your installation of the flatbed scanner driver failed, and
WinXP is performing a (5 minute long) System Restore to correct the problem.
The Fix to both problems: download (free) updated driver from www.canon.com
For your flatbed scanner:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware
Jan 17, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Lost setup disk to Canoscan LiDE 100 scanner, want to install
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu. Then download the required drivers and software.
The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
Aug 27, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
I've installed the software for a canoscan lide 100 scanner. whatever USB port I use for the scanner, my pc says it's not installed
but your computer see device attached? If not thne you have problem with the usb cable. If you computer see the device, then try to update your driver for your operating system
Feb 24, 2010 | Office Equipment & Supplies
Canoscan Lide 30 - want to use on laptop running XP Pro
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
Jun 30, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Driver for canoscan LIDE 500F
Here is link to driver. Click on External Mirror 1 to download. Disconnect scanner from usb before downloading and installing the software, connect back only when required by scanner software or after installation.
Jun 08, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Lide 30 deoesnt work with vista
Scan with Arcsoft PhotoStudio
It's on your disk
works perfectly!!!
May 12, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Dell Inspiron 1525 Laptop Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
