Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washeer has f33 code
Trouble shooting guide says...
Possible causes:
1. Check for crack or holes in washer tub and pressure switch hose.
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Posted on Sep 28, 2010
I have error code f33 .What dose it mean and how do i fix it
F33 System leak
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Solution
  1. Make sure the hot and cold water lines are on and pressurized.
  2. Check for cracks or holes in the washer tub and pressure switch hose.
  3. Replace components if necessary. The pressure switch hose can have a pinhole in it and throw this code.
Feb 27, 2011 | Whirlpool WFW8300SW
My washer is flashing f33 what do i do
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
Press 'pause' and 'cancel' twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool front loader shows F33 error
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block OR
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
mcmione.com
Pl rate me nice for the free help, thnks
Jun 04, 2010 | Whirlpool GHW9200L Front Load Washer
What does the code F11 mean?!
This information is taken directly from the Whirlpool trouble shooting guide we found on our Duet Sport. I quote: "The motor control unit has internal failure; repeating under or over voltage, or over current conditions." Possible Causes/Procedures 1. Unplug washer or disconnect power. 2. Check wire harness connections between the drive motor and the motor control unit. And between the motor control unit and the central control unit. Check the motor and do a continuity test. 3. Plug in washer or reconnect power. 4. Check the motor control unit by by looking for operations of the drive motor. 5. Check the drive motor for powered rotations. 6. Replace the motor control unit.
As previously stated, this is quoted directly from the guide. Hope that helps.
Feb 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-33
Hello there
OR
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirpool duet washer is displaying F33 code. It doesnt spin at a high rate of speed to allow for the clothes to spin dry therefor the door latch will not open.
The F33 error indicates a PUMP DRIVE SYSTEM ERROR and occurs when the connection between pump and the Central Control Unit (CCU) is lost.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
System Leak - Select 'cancel' twice to clear error code. Check for any cracks or holes in the washer tub or pressure switch hose. Replace if damaged.
Also
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F33 displayed in whirlpool duetsport frontloading washer
Sites for spares:
espares.co.uk
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
285 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
