Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Freezer compartment is not staying cold, fan works.
Freezer does not defrost automatically, fan runs, but does not cool down.
  • docquillen Jul 05, 2010
    The freezer is supposed to defrost automatically but it does not. I defrosted it and plugged it back in. The fan is running but it does not keep ice frozen. Does it need freon or is the thermostat bad?
    Thermostat bad
  • 2,272 Answers
If the fan runs but the freezer is not defrosting then its problem of the defrost timer. The timer should work on proper timing and off at proper timing .if the timer becomes short it will remain on for more then required and will remain off when actually required.
the defrost timer is the part which controls the cooling and defrosting in refrigerator .it actually spins as the coldness in the unit. after the temperature reaches to certain coolness it spins back wards and defrosts .if the defrost timer is faulty it will not spin properly and all cooling and defrosting system of the unit will get misaligned. if the timer gets faulty the cooling will reach till over frost and then the fan the coils in the unit will get blocked due to ice built-up and over current will be exerted by the unit to melt that ice. and in this melting ice procedure without defrost timer the unit stops completely .it can effect any section lower or upper or may be both. so the defrost timer at present needs replacement. its like a mini plastic box . color is mostly black or white or creamish . the cost of timer is near to $40.you can get it from
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 05, 2010
  • 677 Answers
Does the light inside the freezer work? Or, can you hear a fan, motor, or other sound coming from the appliance? If so, the freezer is still working. Go to the specific problem you are having with the appliance. If not, try adjusting the thermostat to a colder setting. If your freezer still doesn't work, read on. To check to see if power is getting to the freezer, plug a lamp or other device into the same outlet as the freezer. If there's power, check the fuses or circuit breakers. If that's not the problem, contact a qualified electrician to restore power to the outlet. If there's power to the freezer but it still doesn't work at all, there may be a problem with one of these: Wiring Thermostat Defrost timer Compressor Overload and/or relay The problem with your refrigerator can be difficult to pinpoint without a clear indication of a specific defective component. At this point, we recommend that you see help from a qualified appliance repair technician.
  • ikechukwu joshua
    ikechukwu joshua Jul 05, 2010
    ADAPTIVE DEFROST CONTROL
    The adaptive defrost control assembly is a microprocesser controlled
    defrost timer. This new control allows defrost to occur only when
    needed, compared to mechanical timers which defrost at a preset interval
    whether it is necessary or not. The new control will continually adjust
    defrost intervals based on the amount of time the defrost heater is
    energized. This allows the defrost intervals to be adjusted closer to
    the optimum defrost interval based on use, thus saving energy.
    HOW TO CHECK THE ADAPTIVE DEFROST CONTROL ON MAYTAG
    REFRIGERATORS
    1. Disconnect the unit from the power source.
    2. Open the fresh food door and remove any items on the top shelf.
    3. Remove the light shield and the temperature control housing.
    4. Connect the refrigerator to a wattmeter.
    5. Make sure compressor is running (cold control closed).
    6. Using an insulated number 22 jumper wire short between L1 and Test;
    this will
    put the refrigerator into a defrost for approximately 23 minutes.
    7. The watt meter should read between 500 to 600 watts depending on the
    model.
    Note: If the temperature control is open
    (unit not running and you jumper L1 and
    Test) the unit will cycle through the test
    mode in two seconds and there will be no
    watt draw.
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
Refrigerator is not staying cool freezer still working fine
I would start with the fan. There is a fan that sends cool air into the refrigerator compartment. They have been known to fail. The fan may be behind the refrigerator or behind a panel in the freezer. They are relatively simple to change if you find it. Had one go out a few years ago and has not failed since.
Apr 03, 2011 | Refrigerators
Hi, Our refrigerator has stopped cooling and I desperately need to try to fix it myself. Lights still come on. Fan or something is still running but the freezer still works so I thought maybe that's what...
There is likely a problem with the defrost circuit or cold air circulating fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer and blows it into the fresh food compartment; based on the setting of the thermostat in the fresh food compartment.
When the defrost heater fails, the area that the cooling coil is located in eventually turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the cooling coil is found. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment. Defrost by placing a heat source in the freezer or directing the output of a blow dryer at the coil. If you're unable to access the cooling coil, you can simply empty the freezer and defrost it with a heat source. it will take longer to melt all the frost and ice, but it will work.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost.
This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Oct 07, 2010 | Kenmore Refrigerators
The inside of the refrigerator is not staying cold. The freezer does stay cold. How do I fix the inside temperature so it will keep the food cold?
If any part of the automatic defrosting system isn't working, the evaporator will turn into an iceberg and no cold air will circulate into the lower compartment.
Possible causes in that case could be the defrost timer, the defrost thermostat ("bimetal"), the defrost heater, the defrost thermal fuse (if there is one), or the wiring and plugs connecting them.
Removing the back panel of the freezer compartment should reveal the iceberg and allow you to defrost it with a hair dryer or fan. Then you can get at the parts to test them (except the defrost timer, which may be down by the compressor).
Sep 27, 2009 | Avanti FF1101W Top Freezer Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
