Question about Hitachi 50VS810 50" Rear Projection HDTV
It take about 15 to 20mins for the pic to clear up how can i fix?
I replaced the bulb and it started doing that
  • Hitachi Master
  • 8,457 Answers
U hear alot of clicking within the 15-20 mins.Yes,than,ur tv the ballast board it also dead,require a new ballast board also.The Ballast board,that board help to ignite the the projection bulb.
Posted on Jul 05, 2010
How do i fix a 57 toshiba cinema series exhibiting a wavy distorted pic, which usually occurs after watching for 30 or 45 minutes
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 05, 2015 | Toshiba Televison & Video
My camera used to take very clear pics, now they are very cloudy, how do I fix?
First of all make sure the lens is clean. Wipe it with a clean dry cloth. Next restore your camera to Factory Settings. If it still not working, there might be a hardware issue.
Aug 09, 2012 | Nikon COOLPIX S220 Digital Camera
HL-R5656W Unit made loud pop and pic went black, ordered bulb but there is a loud crackling with some flashing going on when I re-inserted old bulb, is this the ballast that needs replaced?
Wait until you get the new bulb to determine that. The old bulb is probably arching as it tries to start.90% of the time the new bulb will do the trick.
Oct 31, 2009 | Samsung HL-R5656W 56" DLP HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Have a sony kdf-50e2000 pic clear but green
dbrian07, most of these problems are caused by a defect in the optical block or light engine, your description of the problem points out to this particular area. there are some websites that can give you prices for either rebuilt or replacement light engines, you will need to type in your complete model number, and SONY USA.COM has a website i think they also can help you with parts for this model. please leave your feedback if i answered your question. thanks!
Aug 25, 2009 | Sony Televison & Video
INTERMITTENT PICTURE AND SOUND
You were told correctly, you have a bad lamp. When the lamp gets old, the reflector becomes cloudy and instead of reflecting the light, it converts it into heat. As the lamp heats, it draws more power, eventually too much power and the set "recycles" because the lamp is drawing too much power. Replace the lamp, use an original Sony lamp as the aftermarket replacements are known troublemakers. If the bulb fixes the problem (and I know it will because I fix these TV's everyday) be sure to rate this solution. Thanks!
Nov 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Turns off and on by itself after a few minutes of being on
Another post above says replacing the bulb is the answer. I have one coming as I am having the same problem. I will let you know if thats what it is.
Oct 17, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hitachi 50VS810 50" Rear Projection HDTV Logo
273 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
