Question about Dometic Rooftop RV Air Conditioner
Fan motor vibration - Dometic Rooftop RV Air Conditioner
  • Dometic Master
  • 6,674 Answers
Could be motor mount bushings, or bearings going in motor, but another common cause is mud-wasp nests, or other debris on the blades of your condenser fan. You'll need to shut off power at breaker, remove cover on roof unit, and have a look, and clean off as necessary. While power is off try moving motor shaft up and down, side to side, to feel if there is excessive play that may be the cause. This will also allow you to have someone turn unit back on, while you stand back with cover off and observe for possible causes of movement. Turn power back off at breaker for re-install of cover.
Posted on Jul 06, 2010
What is causing Scotsman icemaker to moan
perhaps it's unhappy? I can't say i blame it, if I had to sit there all day in the freezing cold making ice I would moan too.
here's a list of possible problems
If it makes excessive noise:-
Problem and Likely Causes/ Probable Solutions
Fan blade vibrates Blade is bent Replace fan blade
Fan motor mount is broken Replace motor mount
Compressor vibrates Mounting loose Check mounting
Water pump vibrates Pump bearings worn Replace pump
Panels vibrate Mounting screws loose Tighten screws
and ice can groan as it expands, but that only applies to large icebergs
May 14, 2014 | Scotsman Freezers
Vibrating noise when turn on heater/ac fan on 2000 pontiac bonneville
either fan motor is going out ar broken fan wheel, or possibly loose fan motor.
Sep 27, 2012 | 2000 Pontiac Bonneville
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Why does theDashboard vibrates when the heat is
The fan motor is close to the dash and thats coming from the fan motor....prob. the worst when on high...??
Dec 20, 2009 | 1999 Pontiac Grand Prix
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
A/C and heater raddle/vibration when fan control turned on
That vibration is caused by something lying in the fan. This causes an imbalance in the fan that gives off the vibration. You will have to remove the blower motor in order to get to the fan and clear the fan of whatever is stuck in the fan.
Oct 06, 2009 | 2004 Chevrolet TrailBlazer
Vibrating noise
the evaporator fan has become off balance and is vibrating
most likely the fan motor bearings have failed
May 02, 2009 | Refrigerators
Dometic Rooftop RV Air Conditioner Logo
316 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
