Question about Canon PIXMA iP4200 InkJet Photo Printer
How do I print a negative black & white photo...it keeps printing a yellow tone image?
  • 524 Answers
Hi...while you give the printing command go to option and select black and white option. u can get black and white.
If u get yellow tone image means that the catridge of black might hav finshed please check the catridge and replace it.
Posted on Jul 05, 2010
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Tip
Using a color enlarger to print both color and black and white photos
Some enlargers have dials on the front that are labeled yellow, cyan and magenta. These enlargers are made to print both black and white and color photos. To print in colors you use the dials to perfect the colors of your print. Let say that you took a picture and the colors look to be a bit off. In the light you would hold up a color filter to the image and decide which filter makes the color look closest to what you want the final image to look like. Then taking the information on the card you go back into the dark room and adjust the dials on the enlarger according to the card that was used. If you were looking through a green filter then you would lower the number on the magenta dial.
Printing in black and white on an enlarger with these dials is a little different. Since there are no colors in the black and white paper these dials have a different function. They are used to adjust the contrast of an image. If you turn the light on in the enlarger without paper under it and turn the dials you will notice that the magenta will make the light darker. When you print with the yellow and cyan dials at 0 and magenta at around 10-20 this will add contrast the image. You can always develop all your negatives without touching any of these dials, but if you can master them then your images will have a little less flat than those with little to no contrast.
on Oct 01, 2013 | Photography
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Can't print photo in black and white
Could this be the problem? From the User Guide: "Print Color images in Black and White -- Print your color images in black and white to save the ink in your color ink cartridge.
NOTE: You cannot select this setting if you have selected Color Cartridge for all Black Printing"
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
Using Canon iP4600, I'm trying to print a black-and-white photo with a black background and a half-tone image in the front, but I keep getting purplish and black stripes instead of an all black background....
Hi there
Sometimes, printers use colors from the other cartridges in order to form a deep black colour. It does seem that not enough pure black ink is getting onto the paper.
Can you check that there is enough black ink remaining? If so, go to the print options of the program from which you are trying to printer the image, and set the colour output to black or greyscale only. This may be within an option called Printer Preferences from the Print dialogue window of the program from which you are printing from.
Then, print an image as a test and see if it comes out in black only this time.
I look forward to your reply.
Regards
Jul 25, 2009 | Office Equipment & Supplies
Canon ip3500
I have Printer Canon Pixma IP3500 has been error 6502.
What is solution? Please help me.
Jun 09, 2008 | Canon I990 InkJet Photo Printer
Won't print black and white, looks blue
Hi
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
191 people viewed this question
old marine
old marine
