I just purchased a FAX-JX300,set it up,pressed Spanish by mistake,now can not clear it to put it into english.I am sure there is a simple solution but I'm definatly tech. challenged.Thanks,John.
  • thetis Apr 18, 2008
    Sorry,didn't work,thanks for trying,anyone else?
  • 20 Answers
Press [Menu], [Start/Copy] x 2, press Scroll Down button 5 times, press [Start/Copy], press Scroll Down button 2 times, press [Start/Copy], press Scroll Up button 5 times, then press [Start/Copy]..... you done it !
Posted on Apr 18, 2008
  • Syed Osram
    Syed Osram May 13, 2008
    Again, press [MENU], press Scroll Down 1 x, press [START/COPY], press Scroll Down 5x, press [START/COPY], press Scroll Down 2 x, press [START/COPY], here you can see the language listed.Press Scroll Up 12 x and then press [START/COPY]. You're done.
My father has recently bought a FUJIFILM JX300 in Spain where he lives and the instructions are in Spanish, is there any way i can buy a copy of these instructions in English? Regards Heather.
You can download and print the instruction manual (English) in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Aug 18, 2011 | FUJIFILM FinePix JX300 / JX305 Digital...
I have jx300 facsmile, it displays "auto print off". I coudn't make it on. If any body help me to make it on, it will be grate.
Under service mode, MENU and #, under clear, select all. After that you must reenter your settings ( fax no., line type,... )
Jun 23, 2010 | Canon FAX-JX200
I have a fax jx300 with a message of mistake 500, to which it he refers and as I can solve it
This is carriage error related in most cases. You can clean cariage, purge unit gears,... or from the manual replace:
- PR lift shaft - Sheet feed unit
- Main Board ***'y
- Carriage lift sensor unit
Jun 18, 2010 | Canon FAX-JX200
Can I refill my Canon Fax JX300 cartridge?
yes you can refill the #40 cartridge mfor the JX300 - but when you put it in you will get a message saying 'ink volume unknown' and it won't do anything and the yellow light on the machine will be blinking. - to solve this problem hold the stop button down till the count of ten and the machine will work normally except you will get no low ink warning
Tony Rae
Inkspot
London, Ontario Canada
May 22, 2009 | Canon Office Equipment & Supplies
The icons on the left ware coming up in spanish.
Try this:
select MENU
press > (this should get you to the Maintenance/Settings menu
press OK
press > (this should get you to the Device Settings
press OK
press down arrow 3 times (puts you at Language selection
use the up/down arrows to select English
press OK to set, and exit by pressing MENU
everything should be in English now.
Apr 20, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to purchase
yes of course u can change just follow these methods
First, you need to install a Spanish keyboard, and turn on the key combo to
switch.
Go to Control Panel, Clock Language and Region.
Then click on "Change Keyboard or other Input method". The Regional and
Language Options dialogue will appear.
Click on the Keyboards and Languages tab. The Text Services and Input
Languages dialogue will appear.
Under Installed Services, press the Add button, and select an appropriate
Spanish keyboard (eg Spain, Mexico, US etc).
Press Ok to add the selected Keyboard.
Now click the Advanced Key Settings tab, of the Text Services and Input
Languages dialogue. Select a key combination, to alternate between English
and Spanish keyboards (Left-Alt, Shift, by default)
Press Ok to accept changes and dismiss the dialogue.
Your Spanish keyboard should now be ready to use, once you press the
Alt-Shift combo.
this is just the display language settings for full conversion you cannot do u have to buy a spanish version or ask your laptop assembler to put spanish version of vista hope so your problem solves with this solution
May 09, 2008 | Microsoft Windows XP Professional With...
Fax-langauge
I had to get premium assistance,at a cost of course,talked to someone at Canon and resolved the problem.
Apr 18, 2008 | Office Equipment & Supplies
F-60 Muratec Fax Machine
try the following..Press PROGRAM,#, ....REPEAT until the desired language is displayed.
You can still download the operators manual from Muratecs web site... just look under "Legacy" fax machines.
Mar 26, 2008 | Muratec F160 Fax Machines
59 people viewed this question
jasbo
jasbo
