Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
The connection to my router keeps cutting out. Upon a reboot of the router it works fine for 5-30 minutes. I have tried the following: running the setup wizard, resetting the router (with the small button on the back), and changing the properties on the router. What is causing this problem and how do I fix it?
I have the same problem and i'm looking for answers on the internet. Its been quite anoying for the past month - I have a Dlink WBR-1310 Wireless g router. Most of my reading seems to suggest that if a neighbor has a wireless n router, it will give the wireless g router hell. I don't know if this is true or not but someone please help us!!
Posted on Jul 14, 2010
Why does my internet keep losing its connection , this has been happening for 2 weeks now and is getting very annoying , now thinking of changing my provider ..
If it is the wi-fi that keeps dropping, it could be due to any number of reasons. Try rebooting the router- unplug it, wait for a minute, power it back on. Extend all the antennas upward, if you haven't done that. Change the location of the router by moving it around the house/flat. Try relocating it upstairs if you are in a multi-storey building (of course your cabling should allow you to do these). If it has been working fine before, may be there are more users now than before competing for the Wi-fi bandwidth in the neighbourhood. You could ask for a newer router to try out from the provider. If it is the internet connection rather than the wi-fi which gives you the problem, the provider has to sort that out.
Sep 05, 2014 | NetGear DGN2000-100NAS Router
Everytime i try to get on the internet i get connection error 80028EA1 and when i test my connection i get the ip address but not the internet connection and then the same connection error 80028EA1 shows...
Try the following a reboot can sometime fix a lot of different problems.
1. Shut down PC or PC's (ALL CONNECTED DEVICES)
2. Unplug Router/Access Points
3. Unplug Modem Wait Approximatly 2 Minutes
4. Plug in Modem wait 2 Minutes
5. Plug in Router/Access Points Wait 1 Minute
6. Restart/Reboot PC/Connected Devices.
More Information is needed for further Diagnosis! Thank You and Good Luck!!!
Jun 12, 2011 | Computers & Internet
My new laptop keeps losing connection with my ZyXEL P-660HW-T1 V3 router. My old lap top worked fine, what could be the cuase?
The new laptops are not compatible with some of the older model routers.Try turning the power to the router for approximately 10 minutes,shut down your laptop before turning off the power to the router.once the router has been off for ten minutes,turn your laptop back on,as if you are "logging on",let your laptop be idle for about 20 minutes,giving your router time to "reboot" If this does not fix your problem,you'll have to replace your router with one that is more compatible....
Feb 12, 2011 | Zyxel P660HW-D1 Router
MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON CUTTING AFTER ABOUT 10MINS FROM REBOOTING.WHATS THE PROBLEM
There are many reasons why this might be happening.. You could try the following steps..
First connect the modem directly to the computer and see of the problem persists..if yes contact your internet service provider..if the problem doesnt show up with modem then please follow the below steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 07, 2011 | NetGear DG834G Router
Wireless not working
If you can detect the wireless network but you cannot connect to it, check the following:
1. Be sure that you are typing the correct network key (WEP, WPA-PSK).
2. If the wireless is unsecured, but still you can't connect to it, try to change the wireless channel.
3. Try to power cycle the router (disconnect the power cord from the wall socket for 5 minutes, then plug it back in).
4. Reboot the computer and try to turn off / on the WiFi of your laptop.
5. Reconfigure the router's wireless settings.
6. If same problem occur, contact the manufacturer and have them upgrade the firmware of your router.
If you cannot detect the wireless network, try the following:
1. Power cycle the router for 5 minutes.
2. Reboot the computer and try to turn off / on the WiFi of your laptop.
3. Change the angle of the router's antenna.
4. Change the wireless channel.
6. Upgrade the firmware of your router.
If nothing happens, then the router could be defective. Contact the manufacturer for RMA.
Apr 04, 2010 | AT&T 6850G Router (ALL07735)
Cant connect to wireless without rebooting my router
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
This many times fixes issues like your described.
Feb 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 08, 2008 | Computers & Internet
D link wireless router problem.
You can try this. turn off the router and the modem. Leave them off for a minute. Then turn on the modem first, wait for the lights to stabilize and then turn on the router. this will reboot your network. This will make the router and the modem synchronize again.
Jun 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet connectivity problem
try to upgrade the latest firmware for the router and reset and reconfig it..
Dec 27, 2007 | Linksys Wireless-G WRT54G Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
127 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
