Question about Audiovox Bosch 718 World Cellular Phone
Do i need to add rinse aid to a brand new dishwasher?
  • Audiovox Master
  • 8,404 Answers
Only if you want excellent results ...
Posted on Jul 05, 2010
Testimonial: "Thank you"
What brand of deliming agent should be used when deliming this unit?
The chemicals used for this unit are not brand specific. As long as you are using a commercial-grade delimer, you will be fine. Do not pick up a delimer from your local supermarket. Those are not designed for commercial warewashers and can cause further problems. Ecolab is a common brand used . The have a delimer called Lime Away that is very widely used. Also, please remember to drain the water out of your dishwasher and disable your detergent and rinse aide before filling it back up. Then add your delimer and run the unit in manual mode for as long as necessary. Then, drain the unit again, rinse out the wash tank area, enable your detergent and rinse aide, and fill the unit back up. You should be ready to run now.
Jun 17, 2015 | Meiko K44E Dishwasher
Why does the low rinse light stays on?
The obvious answer is that you need to add rinse-aid to the rinse-aid dispenser. Barring that, then you probably have a bad level sensor in the dispenser and would need to replace the whole detergent/rinse-aid dispenser assembly. On the other hand, it could just be a loose or disconnected wire going to the detergent/rinse-aid dispenser.
Oct 09, 2014 | Samsung DW7933LRABB
Our dishes have a white film on them. The "Refill RInse Aid" light is always on. Does that have anything to do with the problem? How do you solve it?
Most likely YES! The rinse aid helps the water to be completely removed and with the water goes the suds, debris, etc. A rinse aid has a sheeting action to effectively remove the water. There are several different brands of rinse aids. Jet Dry is the one that comes immediately to mind.Usually the refill area for the rinse aid is adjacent to the soap dispenser. Your manual will tell you how to add the rinse aid.
Once it's been added, your problem should disappear.I hope this helps. If it does, please return to fixya and rate my answer!
Jun 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher says rinse aid,
From what I get from the question, it is asking to add rinse aid to the rinse aid compartment next to the dish soap compartment.
Dec 21, 2010 | Bosch Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
What does add rinse aid and where do you put it kitchen aid dishwasher
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Jun 27, 2009 | Dishwashers
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Miele Novotronic G842SC Plus
Add the requested rinse aid.. The light is on telling you it's low/empty.
Oct 20, 2008 | Miele 23 in. Novotronic G841 Built-In...
Audiovox Bosch 718 World Cellular Phone Logo
135 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
