When switched on at the mains the power light is all that works
When switched on at the mains the power light comes on at the amp and the speakers make a loud crack. The power light is the only light on and the remote or manual controls only allow the amp to be turned on and off. You can't get anyting else to work.
  • 17,130 Answers
If your speakers are making this noise on switch on please disconnect them and check out if they the speakers are damaged by a continuity test of the impedance. It must show the marked resistance without a short. Then you are lucky. Next open the amplifier and check out on the output side and the power side for failure of mains capacitors/ output drivers/faulty coupling capacitors. Connect a resistance loaded test- speakers whenyou do this test .Switch on and put the set on fopr voltage checks from the output to the preamp. By a signal test you will be able to analyse the gain factor of all teh corresponding stages.It might be possible that your amp is old and some electrolytics have dried up.If so put the amp on for some considerable time and confirm if there is response building up on the controls and panels slowly. If so check onthe board for the suspected passive components and replace all suspected capacitors. Also resolder the main pcb for bad connectivity. I am surre this must work but attampt only if your are familiar to doing this repair. Good day
Posted on Jul 19, 2010
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
Why dont I get sound from my speakers but the radio works
If you have an equaliser, check that you havent accidentally pressed the button which switches between the main input and aux or bluetooth. Right, if you have aftermarket sound system, check that your RCA's/(look like av cables) arent unplugged broken off or damaged. Another thing is to see if the amps come on (usually shown on amp by a green light) red if not on. Check the power wire from the battery to amp, check if fuse is not blown. Ground the amps properly for the amps to come on and check that the power cable is connected properly as well. Another fault could be blown speakers.
Dec 19, 2014 | Cars & Trucks
My Nad 2400 wont power up the two fuses look ok?
Troubleshooting depends on what skills and tools you have. Since the fuses are located inside the amp, then I take it you're comfortable with removing the lid and poking around inside.
So, taking the usual mains power safety precautions....
Check that power from the wall socket is getting through to the amp. Use a multimeter to check the mains voltage as it comes in from the power cord. Also check the power is getting through the mains switch and on to the power supply board.
Disconnect the speakers and then power up the amp. If it comes on, then you've probably got either a cabling or speaker issue. Double check by trying the amp volume (no source, no speakers) and ramp it up slowly to 100%. If the amp still stays on then look at your speakers.
Connect one speaker, add a source of music. Power up and check the volume again but to about 1/3rd volume. If the amp cuts out then you found the bad speaker/wiring. If it ran okay then try with the second speaker attached. Repeat as before.
If the amp won't fore up with no speakers attached then something is either worn out or blown inside. Disconnect the live mains feed. Be careful of any capacitors. They will probably be holding charge.
Do a visual inspection. You're looking for capacitor bulge (Google it) or obvious signs of a diode, resistor or transistor having either blown or overheated.
Sep 18, 2014 | Audio Players & Recorders
No audio from main speakon outputs A and B
Hi, I think in most amps switching to bridge mode simply means the amp supplies its total power through the left channel only. It's the best way to use all of your amp's power but nothing comes out of the right channel. Having speakers connected to both channels would simply mean that only the Left channel works, it would not blow it. Some amps have the speakers wired to binding posts and this varies according to whether you want mono, stereo or bridged. I can't help with the power board sorry
Apr 07, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Myryad ma120 power amp,loud pop when switched off
Sounds like a Electrolytic capacitor has failed. Search backwards from the speaker connections inside the unit to the main PC board. Replace the first ones that you come accross that are linked with the speakers.
Dec 15, 2012 | Myryad Z Series Z160 Amplifier
Power amp r b 981 no power to the speakers. Pre amp seems to be ok. Headphones work.
Check the headphone socket if it cuts out the speakers (normal use) when you plug the headphones in. If it doesn't and you have a switch to switch off the speakers when listening to headphones, check the switch. It may be physical damage or dirt causing the problem, or even loose soldering on the headphone socket. But the fact that headphones work shows the main amp is working. Also make certain the speakers are connected properly.
Sep 28, 2010 | Rotel Audio Players & Recorders
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
I've got 2 blaupunkt amps pushing 2 10" kicker cvr. the only problem im having is that when i start my truck the "protect" lights comes on for about 2 min then it switchs to the "power" light, it that just...
The wiring could be wrong, it sounds like you have taken the live feed from ignition, the main feed should be direct from the battery with an inline fuse as close to the + terminal as you can, the earth lead should be as short as you can from the amp to the chassis, and the remote lead comes from the head unit.
Feb 06, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
70 people viewed this question
 Grubhead
Grubhead
