Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Gas cap the cap for the gas tank ,have to take off with channel locks an put on same way, its almost impossible to put on,any suggestions will be helpful. i hpoe
    Brigadier General:
  • 4,088 Answers
Try swapping caps with the oil tank--if it fits better, buy a new cap as it was probably improperly molded. If no help, the tank opening is probably small for the same reason. You could try filing the cap threads with a small round file to see if you can make it fit better. Good luck!
Posted on Jul 16, 2010
How to replace fuel tank filler tube?
Brother John, you've removed as much as you can for access to the filler. Remove the hose clamps/bands that secure the fill tube and vent tube and then remove the screws around the gas cap that secure the fill tube to the body. With the gas cap off, go below and pull the hose and filler neck down and work the hoses lose with a pair of channel lock pliers and sticking a screwdriver between the metal tube and hose to break the seal. Put on the new filler neck and stick it back up in the body and put the screws back in. THEN put the hose clamps back up and tighten them, put the gas cap back on and your done.
Nov 30, 2014 | 2000 GMC Jimmy
Gas cap stuck won't come off?
Grab a pair of channel locks to get a good grip on the cap and twist counter clockwise. The back pressure created in the tank from the gas depleting can make the cap seem impossible to remove.
Jul 16, 2014 | 2001 Oldsmobile Alero
Water in gas tank
If you cover your bike EVERY time and are still having issues - Find the SOB that is putting something in your tank for you. You can always look into getting a locking gas cap and key from a 2000 Buell M2 cyclone. Looks identical to the cap you have just has a keyhole in it. I would also try buying my fuel someplace else too. Could be getting water from the gas station. If you haven't drained the gas tank completely(pulled the Fuel valve off of the bottom of the tank - not just pulled the fuel line) you probably still have water in there.
Apr 25, 2013 | Buell Motorcycles
My daughters rodeo wouldnt start. Battery is brand new, sounded like it wasnt getting gas. Fuel filter was just black, it has been changed. Truck still wont start. Any ideas?
check the tank is it plastic... if so drop the tank pour gas in bucket if black stuff in the gas take a water hose and spray it out wait till dry put it back on and put gas and try to start it,,, if fuel pump in tank replace it... please let me know how it turns out,,, good luck
Jan 28, 2012 | 1995 Isuzu Rodeo
How to remove the fuel filler neck on my 1999 Dodge Grand Caravan 3.8 ltr. engine
OPEN GAS CAP FLAP THEN YOU NEED TO DRAIN GAS BELOW FILLER NECK.THEN LOOSEN REMOVE SCREWS IN THE GAS CAP FLAP AREA WHERE FILLER TUBE CONNECTS THEN GO UNDERNEATH VAN LOOSEN REMOVE HOSE CLAMPS AND REMOVE THE HOSE AT THE FILLER NECK BELOW THE GAS TANK.SPRAY WD40 AROUND HOSE AREA AT METAL FILLER TUBE STICK OUT GAS TANK.CAREFULLY USE LARGE PAIR OF CHANNEL LOCK PLIERS TO REMOVE WORK HOSE OFF METAL TUBE FROM GAS TANK. IF YOU CANT REMOVE HOSE WITH HANDS.BECAREFUL NOT TO MAKE ANY SPARKS.PLACE RAGS AROUND ANY METAL PARTS TO KEEP CHANNEL LOCKS FROM HITTING METAL MAKING SPARKS.
Jun 23, 2011 | 1999 Dodge Grand Caravan
Lost key for locked gas cap on toyota tacoma
You don't. If there was an easy way to remove it there wouldn't be much appeal for the lock function.
Ideally. you will need to have a locksmith pick it.
Alternative: Drill out the lock cylinder (bad idea, possible debris entering fuel tank).
Or my personal preference: big channel locks.
Oct 17, 2009 | 2002 Toyota Tacoma
CHECK ENGINE LIGHT COMES ON
My guess is you have a leak either in the fuel tank itself or in the plumbing from the cap down to the tank. Have you ever been in a wreck?
When fueling the vehicle, do you see any gas leaking out under the vehicle?
Does the area where the gas cap screws in have any damage that would allow a leak to occur?
Another area to look at is the system that recycles gas fumes back to the gas tank.
Something is not allowing the tank to hold pressure.
Aug 12, 2009 | 2003 GMC Envoy Xl
Check engine keeps coming on, i dont see anything wrong with engine, but i have a locked gas cap and the last time i put gas in and sealed it back up the next morning the check engine light was gone
The fuel tank and lines is a pressurized system that is monitored by the computer and will set a emission code if there is a leak or you fill your tank with the vehicle running.
Jul 18, 2009 | 2003 Chevrolet Cavalier
I put a new gas cap on my 2003 F150 and after driving it a few miles it won't start. I can take the gas cap off and it will start fine. Is the vent tube clogged? Where is the vent tube if this is the...
You have most likely obtained the wrong type of gas cap for your F150. Try using a similar gas cap from another vehicle you may own, or one of your friends. You can also try using the new gas cap on the other car to see if a similar problem occurs.
Jul 13, 2009 | 1989 Ford F 250
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
116 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
