if your remote control is completely dead, first, you need to check the batteries and test the remote with another TV, likewise test your TV with another remote control.
Some times, the fault might not be from the remote control, the fault might be from the TV remote sensor. This happens a lot of time where remote looks dead, but the TV sensor might be the one that is dead.
So confirm if the remote is actually dead before you thing of getting another one. But if it happens that the remote is truly dead, then you need to get another remote control because, remote are hardly repaired.
You can open the remote battery area, check if the metal there is not rust, it its rust, then maybe the batteries are not contacting as a result of the rust. Get a flat screw driver and use it to scratch the rust off. Again, open the remote control and make sure the battery terminals are well fitted on the remote board.
If the remote connections seems right, then you have to get another remote control.
Good luck.
Follow this advise...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
