Question about Razor E100 Electric Scooters Red
I have an e-scooter and the fuse holder is broken how do i fix it ?
  • 8,404 Answers
Get a replacement holder at the Radio Shack ... you will have to modify to install in all probability.
Posted on Jul 05, 2010
Why is my scooter blowing fuse?
Hi, Amanda before diagnosing your blown fuse issue check the bottom of your seat if it's metal and comes in close proximity to the positive battery post to need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) also you are going to need a wiring from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.razor.com/tr/wp-content/uploads/sites/6/2011/11/PocketMod_US_Version1_01-10_US.pdf Razor E100 Troubleshooting
Jul 05, 2016 | Motorcycles
I have a 2009 E Charm Scooter That main fuse blows when ECM is plugged in
Hi, Denice you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day. 2009 Charm diagram SCOOTER PROFESSOR
HOW TO FIX YOUR CHINESE SCOOTER
CFMOTO CHARM 125 150 EFI SCOOTER SERVICE REPAIR PDF MANUAL DOWNLOAD 2009...
http://www.alpha-sports.com/Parts/c_2008-2011echarme.htm
CF Moto Charm 150 2010
Oct 05, 2014 | 2009 C_F Moto 150 Charm AutoMatic
Why my car wont go into gaer when i start it
Many of these require that you apply brake n order to put it into gear. Fuse probably is in circuit for brake pedal to let control unit know you have foot on brake. It is likely that the in-line fuse holder has broken (quite common) and thus the fuse fell out. Remove any under dash panels as needed to be able to see into this area, and you should find a wire with a part of broken fuse holder attached. Find the two ends and splice in a new fuse holder and fuse=fixed!
Jul 14, 2014 | 1998 Mercury Grand Marquis
Where can I get the fuse holder for a F5A450V fuse for my Micro computer massage chair. My ******** brother lost the housing when he was supposed to get the fuse. Can i use black tape to hold it in?
I believe that your looking for an "in-line" fuse holder. These are common and can be purchased from several online sulpiers. Need on pick on similar to the one that was broken. Here's a link to Radio Shack for starters: Fuse holders taps
P.S. Don't use black tape. Fix it right or you could end up starting a fire.
May 22, 2014 | Health & Beauty
Dead electrical circuit - how to trace
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
finding electrical short motorcycle
Fix electrical shorts in your own car or truck or motorcycle
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Jan 10, 2014 | 2007 Diamo Tracer 250
I have a aprilla 2004 scooter the fuse are always blowing out the fuses for the voltage regulator. can you please help me why is it doing this
Hi, Bonnyrodrigu you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue, please visit the websites below. Good luck and have a nice day. DOWNLOAD 2004 Aprilia Atlantic 500
Nov 05, 2010 | 2004 Aprilia Atlantic 500
CRT Scooter just quit working and doesn't accept battery charge.
Hi. There is often an in-line fuse for the voltage to run the controller. Often the charger feed goes through this fuse. Check the fuses. Sometimes the fuse is OK, but the contacts in the fuse holder are faulty. Also check the battery connectors, and where the battery leads are fixed to the batteries.
I have removed many connectors from battery leads and connected the leads to the batteries without in-line connectors.
Good luck. Neil.
Jun 01, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
I want to get my scooter fixed
Throttle wire is broken and needs to be changed.
Simple job for any good mechanic.
Search in yellow/white pages or nearby) for a reasonable mechanic who can do the job in your budget.
May 30, 2009 | Transport Schwinn Rechargeable Portable ...
Fuse holders weakened and broken
Apart from somebody spilling something on them my best guess would be something in the amp seriously overheating. Check out the power section: transformer, rectifers, voltage control section for faults. The holders can be got at Maplin (uk) or Radio Shack (US), but find the fault first BE CAREFUL it could start a fire!
Dec 11, 2008 | Audio Players & Recorders
Razor E100 Electric Scooters Red Logo
153 people viewed this question
Top Razor Sport & Outdoor - Others Experts
Tony
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
