Question about Pool & Spa
The power to the heater is tripping as soon as it is switched on
  • 8,404 Answers
GFI protected? you have a leak somewhere ... Not GFI protected, you have a short. Is this 110 or 220Volts?
Posted on Jul 05, 2010
Convection electric heater by " de long hi" Heater does not turn on when pres the "power on" switch
fuse in plug often blows. but delhonghi are weird. i've got one that trips unless i put an rcd plug between it and the wall socket to stop it tripping. is yours tripping off straight away or just not coming on at all? listen for a cvlick as soon as u switch on. try another wall socket. check fuse
Apr 25, 2018 | Heating & Cooling
Why is it tripping?! what can i try next? thanks
Is their not two elements, one at the top too? If it is tripping on the high limit switch it could be the thermostat Try checking the grounding of the unit.
. http://en.wikipedia.org/wiki/Residual-current_device
Jan 14, 2015 | Water Water Heaters
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
As soon as I plug in my 2007 F-350 it trips the GFCI plug. I am an electrician and I check the ohm's and it all seems good?
The truck heater is pulling a few amps and if the gfci plug has a weak switch, it will trip it. change the gfci plug and try that.
Dec 22, 2010 | Ford F-350 Cars & Trucks
When furnace runs blower won't run.as soon as furnace stops blower runs. They never both run.
Sounds like fan limit switch/fan timer
This will cause the main burner to run untill the over tempreture switch is tripped therefore shuting gas supply and running fan on high till over heat condition is resolved then it will restart burner and repeat
continuing to run heater like this will cause heat exchanger split.
May 13, 2010 | Heating & Cooling
My machine flicks the mains switch as soon as i turn it on, both washing and drying. it first flicked the safety switch about halfway through a dry load...what could it be?
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
This sounds like a heater issue since it's tripping the power on both the wash & dryer, in events of overheating the machine will trip your power for safty & to prevent the risk of fire however since you mention that it trips the power as soon as you switch it on you could have a blocked pump or burnt out motor too if your finding that the machine is tripping the power earlyer & earlyer each time you retry i would focas on the motor or the pump 1st
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys..
remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Apr 22, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Miele novotronic 510 keeps tripping fuses
Possibly the heater bank. Try running it on cool air, still same problem, then you will need to post more info. IE. Does it trip when you switch it on via the button?
Does it trip as soon as you press start?
Does it trip after a seconds of mins after you start it?
Feb 08, 2008 | Dryers
Pool & Spa Logo
66 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
