Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Hydraulic pump chattering
The loader on my 2020 John Deere tractor is slow to raise up and jerks as it raises. Also, at a slow idle, it has rattling sound coming from the hydraulic lines to the front hydraulic pump. When increasing the rpms,
the rattling decreases in volume.
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
In the worst scenario, the follower, or the piece that senses load on the control shaft , may have broken. Several causes could be the culprit, but happened on my 2520 . Fix requires total disassembly of final drive and differential to remove control arm and repair the follower. Good luck.
Posted on Jun 27, 2012
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
I have a John deere 2651. I tested the main pump but continue to have the same problem. When the lift is raised I struggle to turn the steering. Al filters was also chnaged. Where does this pressure relief...
is the hydraulic fluid level correct ??? sounds like you're running out of hydraulic fluid. because if your trying to turn as your raising the lift then i could see a problem but if it's lifted and you're having an issue then fluid comes to mind first
Dec 04, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
Sep 02, 2009 | John Deere 420,1020,2010,2020,2510,2520...
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Mar 26, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
446 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
