Question about Samsung SP-R4232 42 in. Plasma HDTV
Tv turns on & off on its own
Used the remote control to change the channel...tv began to turn on and off by itself. Unplugged tv for various intervals over last 24 hours...tv continues to do the same thing each time its plugged in
  • Anonymous Aug 22, 2008
    MY TV IS LOCKED AND I PRESS THE REMOTE CONTROL AND IS LOCKED.IS A LOGIC TV
  • klovely Nov 07, 2008
    my plasma hdtv turns on and off..HELP!!!
    Genius:
  • Samsung Master
  • 1,689 Answers
This can be a logic control fault in the uPC, or a fault in the power supply that is triggering false commands. It can also be a cold solder connection that is in such a way that it is triggering the off/on sequence.
The set will need to be properly serviced.
Jerry G.
Posted on Apr 18, 2008
RCA P52921 changed channels by itself and unplugged it to reset it and
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Mar 31, 2008 | RCA P52921 52" Rear Projection Television
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
My rca tv turns off and on by itself
Is there a prankster nearby thast has a remote tuned to your set? As a young lad I used to play this trick on my neighbors daughter.
You should also investigate whether it is timed.. that is has a regular interval or time that it does happen. It could be another appliancwe doing this A/C ,Security system or some other eklectronic device. The dog has the remote under the cushion?
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | RCA P52960 52" Rear Projection Television
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Symphonic TV WF-13
I have had a problem like what you stated.
I turned TV off. Then unplugged the TV, for 5 mins.
Then plugged the TV back in the power outlet.
Also try the menu button on the TV itself, NOT the remote.
Scroll thru the menu button, with alt volumn & channel buttons
make changes.
Good Luck
JayHzg
Mar 30, 2008 | Televison & Video
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
TV Stuck in TV Guide Plus+ Installation Mode
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Samsung SP-R4232 42 in. Plasma HDTV Logo
136 people viewed this question
Henry  Thomas
Henry Thomas
