Question about Fisher and Paykel GWL11 Top Load Washer
I own a GWL11 top load washer. Yesterday it would not advance from the final rinse to the spin cycle. I stopped and reran from the final rinse location several times when the power light went out. I checked outlet, good, Pump spins freely. Motor with red blade looks a bit rusty. Tried to call for service. No help for weeks. Help! Thank you, Randy
  • rnsgilds Jul 05, 2010
    Had water leakage underneath for a couple days. Then would not drain and had steady beep every second. Tried setting to final spin. Would pump water for a few seconds then shut off. Now will not power up. Outlet good and power getting to power box inside control panel. This morning woke up to several gallons of water on the floor but the remaining inch or two in the washer had not changed. We are thinking it is the pump and controller and would like to know how to repair.
    President:
  • 1,554 Answers
The water pump is indeed leaking then shorted out leading to the damage of the motor controller module as manifested by the failure of the machine to turn on. It would be a costly fix since you have to replace both for the machine to work again.
Lay the washer on its back on protective material but ensure that the washer is slightly raised at the top to prevent residual water in the tub from spilling out. Remove the base panel by easing the tabs, located at each corner, with long nosed pliers, then pry the panel off using a flat bladed screwdriver. Remove the drain hose from the pump then unscrew the pump from the bottom of the tub and remove it. Reinstall the new pump into position and reconnect the drain hose.
Remove the 2 screws from the rear of the console then raise the console for access to the Motor Controller Module. Remove the screw securing the Motor Controller Module to the cover and lift the Motor Controller Module up at the pressure sensor end and ease away from the inlet chamber. A small quantity of water will discharge from the Inlet Chamber and heat-sink. Dry off the water then install the new Motor Controller Module. Secure the console back into position and you are good to go.
Posted on Jul 05, 2010
  • Jahn27
    Jahn27 Jul 05, 2010
    Feel free to update us about the development of the repair. Please accept and rate the advice/solution that helped you address the problem or at least gave you
    the right insights on what the problem is and how to address it. Failure to do so will
    automatically give credit to the first advice/solution no matter how
    inappropriate or not helpful it is. Accepting a
    solution/advice does not prevent or stop you from communicating with an
    expert, You can still post comments as long as you need assistance with
    regard to the problem stated herein.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the lid switch is fine. Check the connector voltage which should be 110V. Also check that nothing is jamming the motor to hinder it to rotate. Please apply some grease on the rusted part. If still the issue persists, then it means that the pressure switch or timer has gone bad. Replace whichever is required. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not do final rinse or spin
Before the final rinse and/or spin can start the pump has to kick in. Tilt the machine back on an angle, on the right-hand side (closes to the front) is the pump motor. there will be 2 sets of wires, one green (earth), the other (brown and white), make sure they have not become loose.
I had exactly the same problem, I just unplugged the brown and white with needle nose pliers and squeeze the end (don't break it) & plugged it back in.
DISCONNECT FROM POWER before doing any of the above, good luck.
Nov 22, 2008 | Fisher and Paykel GWL11 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
