Question about Sony VAIO VGC-RB42G PC Desktop
Power got cut to my home.
A transformer down the street blew and knocked out power to my street. I didn't have time to check the pc before I had to leave for work but when I came home, the green power indicator light on the back was flashing and a rythmic popping noise was coming from the speakers. The computer won't turn on. Is my mother board fried?
  • 3 more comments
  • Facemelter99 Apr 18, 2008
    Thanks for the info
  • Facemelter99 Apr 22, 2008
    It was the power supply. I replaced it and everything's working fine.
  • Rictor Jun 05, 2008
    What power supply did you use? The Vaio has a proprietary power supply that's very expensive from Sony. Did you find a 3rd party power supply that fit the case and worked?
  • Anonymous Sep 01, 2008
    • green lite flashes and wont start unplug main plug om mother board with power on and will start , but when i shut it down some times it will start and some times it wont then i have to unplug at the mother board do i need a new power supply and if so where do i get one and do you have a part # thanks don
  • marinc
    marinc Oct 21, 2008
    Turned off the PC. Turned back on and the green light start flashing.
    If i disconect from the motheboard, it would stay green.
    Conected to motherboard, will flash.
    Please help.
    Scholar:
  • 160 Answers
For solving your problem do the following:
1. Remove the SMPS connectors from the motherboard
2. Place the connectors again and switch on the computer
if its not solved check that the SMPS is getting out of 12V using the multimeter
Replace the SMPS with another one
Let me know if your problem is solved and rate me as FIXYA!
Posted on May 11, 2008
    Problem Solver:
  • 8 Answers
Its the power supply, about $50-$60 retail, depending on where you get the part.
Worst case senario, your motherboard is fried, which would mean that it can be at least $400 to get it back up and running. If that's the case, I would recommend a new PC, given that most mid-end systems begin at that price mark.
Posted on Apr 18, 2008
  • 975 Answers
Looks like you need to replace the POWER SUPPLY unit , check for blown fuses , voltage regulator , circuit breaker . .
before buying a new one , and lets hope that it didnt damage
the MOTHERBOARD , i hope this info helps
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
My iphone froze so i did the shut dowwn presseger which is the sleep button and the home button and it cut off then now when i try to cut it on it just sits on the apple symbol and stays there please help
The timing for that process should be precise. You can do that same process again, but this time, make sure to count each second.
First, you can try forcing your iDevice to reboot by doing this: Without connecting your iDevice to a computer, press and hold both the power button for 3 to 5 seconds until it reboots.
If that didn't work, try using TinyUmbrella to kick your device out of recovery. Download TinyUmbrella for PC HERE or use the link below: If those 2 options didn't work, option 3 would be to restore your iDevice while in DFU mode. Here's a classic step-by-step guide on how to do that:
  1. Plug/connect your iDevice to a computer (PC or Mac)
  2. Turn it OFF
  3. Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
  4. Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
  5. Open iTunes and restore your iDevice.
WARNING: Restoring will delete all data on your iDevice.
If you don't get it at first, try holding the buttons for lesser time or see the other procedures and some screenshots on my tip (link below):
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Is this tip helpful?
Jul 10, 2011 | Apple iPhone Smartphone
I have just set up a new mains powered electric fence and i need to install a cut out switch but i wired it in the way i was told and the system dont work. what am i doin wrong
Where are you checking the power at? The transformer? Or the fence wire itself? The power to the transformer is basic 110 volt, 15 or 20 amp circuit, need to be in a pipe or somewhat protected, , like through a wall. The transfomrer should be accessible, and can be switched by a light switch in a box. Your fence wire has to be a continuous run, no breaks, and make a complete circuit. It comes in different voltages, And will blow out a tester in a flash if it is on the wrong setting, so start with the high voltage and work your way down when testing. Some are just a tickle, some will knock you on your ****. So be careful. Make sure the breaker is on and good, and the plug is good if it has one. Also, it should hum or buzz when running. The horse will only have to touch it one time and he will never go near it again. Hope this helps.
Oct 05, 2010 | Electrical Supplies
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
Apr 26, 2010 | Sunbeam Transformer (ICTRBA) ATX Full...
CARRIER AIR CONDITIONER/HEAT PUMP PROBLEM WOULD NOT RESPOND TO THERMOSTAT. UNIT IS AT LAKE HOUSE WHERE WE DO HAVE BAD STORMS. IN CHECKING, INSIDE PART OF UNIT HAD BURNED UP THE TRANSFORMER BUT NOT...
what I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side.
A quick way if the primary side is burningout due to a problem with the low volt side:
1 MArk all the thermostat wires at the indoor unit
2 Disconnect them at the indoor unit.
3 Check main line voltage before proceeding (A 208 volt is not considered 220V and 240v Is not considered 208V> In these circumstances the voltage may have changed with the power company replacing a transformer and now you need to change the main power input lines at your control transformer for the correct operating voltage). If okj then proceed:
4 If you have an amp meter attach it to one of the lines going to the transformer.
5 Apply main power and listen for hum, note if smell starts again and if so problem has to be in board or main incoming voltage too high or too low. Amp draw should be less than 3 amps.
6 If your to this point and still havent found any trouble in the above as of yet, Connect the wire marked "C" together. Then just touch the thermostat wires one at a time to the places where they go on the indoor unit and watch the amp meter. If you donmt see the meter jump the circut is probably ok but leave them disconnected until you touch all of them to the correct place or wire. Here is a possible problem I ahve seen a thermostat wireing problem if the wires are stripped too far and a "whisker" of the wire sticks out and allowes one of the other wires to cross short out. In this case just cut off the excess wire or bend it over out of the way asnd continue with the test. You can always cut it off later after the tests. If you see the meter jump up and stay up and /or blowes the fuse the wire that you used and it blew is where to consentrate.
7 No wiring problem found means that you could have a relay or contactor not pulling in properly.
and this will cause the amp draw to go way over the transformers power out put or VA rating.
8 Inspect the thermostat wiring for the "whisker" I mentioned above.
9 If you have done this to the end of the thermostat wires and your main incomming voltage is correctly wired in on the transformer andf your relays and contactors are pulling in evenly and not delaying excessively your problem should be fixed.
If this helps you please rate me as high as you can and thank you for using fixya.
Apr 24, 2009 | Heating & Cooling
We was driving,car started knocking real hard then stalled several times kept starting it lose of power continually.5 miles cut off 2 minutes to start but made it home.redid timing,oi change ect,now car...
I just did one of these it blew the head gasket between 2 and 3 cylinder and burnt the piston.You can do a compression test to confirm none of them should be below 75 to 100 pounds .
Dec 01, 2008 | Saturn SL1 Cars & Trucks
Computer wont turn on
big blue flash! I would say one or more of the filter capacitors just blew up! time for a new power supply. the AC goes into the unit and a surge suppressor is across the line - looks like an orange colored disk - from there it goes to a step down transformer to a multiple output secondary. on the secondary there are numerous "bridge rectifier" circuits that take the AC and change it to usable
dc. That DC is filtered with large capacitance capacitors. I have a site if I can still find it that has large wattage power supplies. I'll find it and get back to you.
Dec 15, 2007 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Bose 321
You probably blew up several components in the power
supply circuit, but yes it can be fixed.
Just take it down to your local TV repair shop.
Oh wait, those don't exist anymore.
-John
Nov 10, 2007 | Bose Lifestyle 30 System
Power cuts out
This problem happend to my sony system about a year ago. It was the amp that blew in mine because of the fan inside the system was not coming on when it should of. I found that when i had put my PC in the AUX jacks it blew the fan on me, so every time the volume got to 15 the system would just shut down and not come back on at all, or it would need time to cool down before it would start up again. Take it to a shop and get it looked at by someone that knows what there doing. Please dont try and do this yourself.
Aug 14, 2006 | Aiwa NSX-AJ205 CD Shelf System
Sony VAIO VGC-RB42G PC Desktop Logo
74 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
