Question about Canon EOS 500D / Digital Rebel T1i Digital Camera
The camera is focusing but the in the viewfinder it is not focusing. I have turned the camera on and off, reset the lens, and cleaned the sensors.
Right to the viewfinder there is a knob to compensate vision problems, this knob i used for people with prescription glasses should use it if they want to look through the viewfinder without their glasses Move the knob either way until YOU see it in focus. Make sure the dot inside to the right is illuminated which means THE CAMERA is in focus.
Posted on Nov 22, 2010
When using any lens, the view through the viewfinder has small spots like a liquid was sprayed on a optical component. What is this and how can I fix it?
It could be on the mirror, the underside of the focusing screen, or the back of the viewfinder. All three can be inspected visually.
The back of the viewfinder can be cleaned with any window cleaner. Don't spray any directly onto the camera, but rather onto a clean microfiber cloth and then wipe the viewfinder clean.
The mirror and the focusing screen are more delicate. First try a handheld blower (NOT canned compressed air). If that doesn't do it, try a camel-hair brush. Only then resort to wiping it with a clean dry microfiber cloth. Use common sense, and avoid scratching the mirror/focusing screen.
If it's on the inside, the camera will need professional cleaning.
Sep 28, 2012 | Nikon D80 Digital Camera with 18-135mm...
The screen of the viewfinder has a black dot.. i tried to clean it but it cant be removed,..how can i removed it?
Remove the lens of your camera, do it in a clean room, look at the mirror insie the lens to see if the dot is not there rather that on the outside of your viewfinder.
If it is not there it might be on the inside part of the focusing screen. Still inside the camera look at the upper part of the body, the focusing screen looks opaque.
If you still cant find the dot it might be on the inner side of the focusing screen.
Here is a tutorial on how to remove it on a d70 it is essentially the same thing on your camera.
Otherwise it can also be on the inner part of the viewfinder. In this case I recommend to send the camera to a repair shop as the removing of the viewfinder seems to be more difficult on the d3000 than on other camera.
Hope this helps.
May 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Jul 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Picture focusing is all blured
you have a diopter next to the viewfinder. it's for
people who wear glasses, turn the small knob and it will focus what you see in the viewfinder. Green lines is your ccd - the sensor - the eye of the camera - see your local AUTHORIZED service center for repair of this issue
Apr 13, 2009 | Cameras
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Unclear viewfinder
remove the lens, inside and
up in the top you will see the the lens port, is it dirty.
clean it with a lens cleaner.
and
some cameras ( I don't exactly know this one) has a focus near the back viewfinder for folks that wear glasses.
Jan 26, 2008 | Leica M6 TTL .58 35mm Rangefinder Camera
My camera cannot focus
Are both the lens and camera set to autofocus?
Jan 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
135 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
