Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
My dishwasher wont drain, it is holding water
    President:
  • 1,197 Answers
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check thesump area for paper or any other large object clogging the drain. A cupor so of water in the sump area of your dishwasher is normal and it isthere to prevent the seals from drying out. The dishwasher will pumpthis old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly,the motor, and the pump. If your dishwasher uses a belt to drive thepump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, makesure that the drain plug on the disposer has been removed. It's just alittle plastic piece that blocks the hole where you hook the dishwasherdrain hose. If your dishwasher drains through the garbage disposer, youneed to run the garbage disposer before you run the dishwasher to makesure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbagedisposal or drain line. If an obstruction has blocked this, then yourdishwasher won't drain. The drain hose is connected by clamps to thedrain valve and the disposer or drain pipe. Remove it and visuallyinspect it for a clog or a kink. Try to remove any debris. If it is ingood condition, just put it back on, and if not, purchase a new one toinstall.
If you don't have an air gap in the drain line, at least use a highdrain loop. Making a large loop about 18" off the ground with the drainline can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. Theair gap is there to prevent any siphoning of standing water from thesink. When your dishwasher drains, the air gap diaphragm will form aseal and allow the water to drain properly. If the diaphragm in the airgap is faulty, it’s possible that water can leak onto the cabinet andinto the sink area. When this happens, then the air gap must bereplaced.
Like the inlet valve, there is also a drain valve on most models. Whenno power goes to the drain valve it remains closed and prevents waterfrom leaving the machine. When the valve receives power during thedrain cycle, the solenoid opens and allows the water to leave themachine. If your drain hose is attached directly to the pump, you don'thave a drain valve. The motor simply reverses and the pump sends thewater in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may notdrain. Make sure you have power to the unit. If you notice that themotor hums but won't turn, it could be seized, and you probably need toreplace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs,you’ll need to open the pump and remove any debris buildup. Thedishwasher pump is usually mounted directly to the motor and runs offthe motor as well. The pump is also attached to the bottom of yourdishwasher and pushes the water from the dishwasher.
Posted on Sep 03, 2010
Can't change cycle water wont go away
There should be a reset on the controls, either a button that you hold on for 3+secs or two buttons you press simultaneously indicates on the panel by a dot under there relevant buttons, joined by a line. Please post the ENr if this does not work
Mar 22, 2013 | Neff Dishwashers
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishmachine will not hold water. Its draining as you fill it?
0
Does not hold water Faulty #3 micro switch (drain) Replace switch, P/N 00411.00
Clogged or defective drain valve Clean and/ or replace drain valve, P/N 04113.00
Nov 11, 2011 | Cma Dishmachines L-1X Dishwasher
Water is not drain completely after wash.
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Miele 24 in. G870 Built-in Dishwasher
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
Water wont drain out of bottom of tub. The dishwasher works fine, it just wont drain the dirty water out. If I restart it to wash again, the dishes are washed in the dirty water.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jul 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Water wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 12, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Water not pumped out of dishwasher
To cut a long story short, lower the drain pipe as close to the floor as you can. Some dish washers have a non return rubber which holds the water in the cabinet until asked to drain.Meaning water wont just flow out with pipe being low.(Im assuming the drain pump is operating correctly).Check if this alteration makes any difference.
Nov 13, 2009 | Dishwashers
Whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Feb 19, 2008 | Dishwashers
Err4 came on drain clogged..have fixed but cant get error to stop
hold the start button in for at least 3 seconds and it should reset
Dec 14, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
76 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
