Question about Hunter Dryers
The ceiling fan motor hums
I have a ceiling fan controlled by a variable speed control for 35 years, and it ran quietly, and later, it hums, so I replaced with 3 speed control, and still hums at the same volume. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • AsshoIe Jul 05, 2010
    It still spins, but I solved the hum problem, and started using a dimmer again. I have another problem, is that it wobbles a lot on medium speed range, but still wobble a bit on the high speed. I replaced all of the blade iron, and still wobbling. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 1,498 Answers
Over there years, dust can accumulate inside the motor, getting under the contacts that transfer electricity to the motor. The motor needs a minimum amount of energy to work. When the contacts can no longer transfer that amount it will sit there and hum.
Buy some 'canned air'. It's used to clean keyboards and computers. It works great to blow out dust from electronics and motors.
The age of the fan may also be a problem. But if you can spin it by hand, it's likely the dust is the problem.
Best regards,
Mike
Posted on Jul 05, 2010
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan hums.............
could be a vibration or the motor going bad try some spray lubricant and tightening any loose screws or connections
Aug 28, 2009 | Hampton Bay 36 In. San Marino in Brushed...
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
397 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
