Question about Bunn NHB Coffee Maker
I did the initialization as per the directions and the water was hot. When I make the coffee, the warmer button will not come on and the coffee is cold. I turned on the vacation button for 15 minutes and it was hot again and the warmer button automatically came on. Again when I made the coffee it was cold and the warmer button would not light up.
Sounds like something is miswired from the factory. Note that the tank heater switch on most home brewer models also acts as the "master" power switch. If the tank heater switch is not on, the warmer switch will not work, either - this is normal. Under normal conditions, the tank heater (or vacation switch) should always remain on, except if you are leaving on vacation.
Posted on Aug 09, 2008
Water does not come out of water spout and will not brew after pressing start button
make sure the water is hooked up in the back properly and turned on. the solenoid tells it when to brew, but the spigot feeds right from the waterline.
Jan 21, 2015 | Bunn CWT15 Automatic 12 Cup Coffee Brewer...
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
Hi all. In desperate need of help. I have a La Cimbali M29 Select. I am unable to get hot water from the hot water tap and when the machine dispenses a shot of coffee, I have to turn the machine of...
From your description it sound that the button strip need to be replaced. All the buttons of the coffees and also for hot water are all set in one unit the button strip. This like a membrane and is located under the buttons. This is frequent problem with m29 select since the connector of the button strip it is exposed under the cup warmer area and is very easy to absorb the humidity from steam escape inside the machine and when one short circuit it happens then since the whole strip is one unit it will mull faction as you described.
Jun 14, 2011 | Espresso RMI La Cimbali Espresso Machine
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
The heater plate on cuisinart cbc-1600 coffee maker does not stay on after brewing cycle to keep coffee hot. is this normal operation?
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
Feb 01, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
I lost my directions to my bunn coffeemaker. Can you tell me how to make the first cup of coffee in a bunn? Is there just one place to pour the water? Fo you leave it plugged in all the time?
it has a reserv tank equal to 2 pots which are hot all the time
the power switch is only for the warmer plate
you get out about what you pour in,
Nov 23, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
247 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
