Question about Whirlpool EL7ATRRKS Refrigerator
Water in bottom of fridge. how do i clean drain hose
  • 4,793 Answers
Use a meat syringe and bleach or milton fluid to blow out the vent pipe.....
Posted on Jul 05, 2010
Vcff136ss freezer drain hose
look at the bottom in the back for a small (usually black) rubber hose. this wil be the drain and the only way to clean them that I am aware if is to blow up through it ( makes amess inside the freezer or fridge but does work. some models drain the freezer into a funnel like thing on the back wall inside the fridge and then to outside.
Jan 02, 2014 | Viking VCFF136SS 36" Professional Series...
Our refrigerator is getting a pool of water underneath the crisper bins. We do not have the ice maker hooked up. Water drips down and freezes into ice on the bottom of the refrigerator inside. I am not...
water is coming from the defrost cycle and is not making it to the drain pan on the bottom. try cleaning the coils and if you can locate the drain that goes to the pan and blow in it this will clear it out. thank you.
Apr 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Where and how can I clean the drain hose on the Frigidare Ref. Water draining in Freezer Bottom
the drain hose runs from the bottom of the fzr to the tray under the fridge. The easiest point to access it is in the fridge compartment there will be a ketch basin (a plastic piece that ketches water from the freezer) with a plastic tube attached to it. This tube is what you want to clean I use compressed air on the tube and to blow up into fzr. good luck
Aug 16, 2010 | Refrigerators
The freezer leaks water and the fridge is 43 degrees and full of condensation on the inside
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Hope this works...............
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
GE Profile TBX22PC fridge water problems
hi thanks for the question you have a drain problem the drain tube from freezer to the drip pan behind and under neath the fridge you have to clean that drain sometimes you have to shut the fridge down for 24 hrs let the ice melt in the drain tube cause you cant get at it so let thaw and then clean out the drain hose thanks for your question the appliance doc
Sep 18, 2008 | Refrigerators
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Whirlpool EL7ATRRKS Refrigerator Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
