Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the level in the bowl? Thanks in advance. Keith..
    Scholar:
  • Saniflo Expert
  • 115 Answers
The Saniplus has a pressure chamber and at the bottom is a rubber membrane which acts as a float switch. Water pressure pushes up on the membrane, the unit turns on, pumps out the waste and as the pressure is released, the membrane goes back down and shuts off. So the problem might be a warped membrane, something stuck at the bottom of the membrane or the microswitch may be stuck on the on position. You will have to open the unit and remove the motor and pressure chamber to inspect it. Also the water level on the toilet is meant to be very low, Saniflo uses a rear discharge toilet, not a bottom discharge (standard toilet). Unfortunately the water level cannot be adjusted on Saniflo toilets.
Posted on Aug 24, 2010
    Scholar:
  • 56 Answers
Hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Posted on Jul 08, 2010
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 | Home
Toilet stools whistle after flushing
This could be caused by the sound of water jetting into the water tank. Just open the tap to the water tank slightly more until the whistling stops. The flusher valve in the tank may be leaking, causing the water jet to open again and the whistling noise.
Apr 26, 2016 | Home
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
I have a 703A5B fluid master flush unit on my toilet when I flush the water fills the dump tank then keeps running
Hi pete4270...
You can try setting the water level a bit lower by lowering the float ball.
This may solve your problem.
If the flushing unit is still leaking by, then it is time to replace it, there is no repair to these units.
Please take time to rate me
Sep 01, 2011 | Home
Pump noise in rear of car keeps running / Gas pump or load leveller / seems longer run time olately in cold weather ( 1999 olds aurora)
you might have a leak in the rear suspension load leveler. check connections with soapy water. locate where sound is coming from. fuel pump in tank is a slight hum and not that noticable, but the air comp for load leveler is. Also spray around rubber boots on shocks, also check load leveler switch on axle to frame for broken or loose lever control.
Jan 21, 2011 | 1999 Oldsmobile Aurora
I bought an American Standard toilet about 3 months ago, ever since it was installed (by me) the water in the tank continues to run like its trying to fill it up. I have tried numerous time to adjust the...
There are several things you can check. Make sure that adjustment on flush handle to flapper is free and not binding and holding flapper open.Make sure that seating surface for flapper is clean and does not have any rough spots on it.If it does you can empty tank and dry it off then sand any rough spots with sandpaper. Also make sure that tube from flush valve to overflow tube is not below water level in tank when it shuts off as this can cause it to syphon water out of tank and refill. If it needs to be trimmed then cut tube so it is above water level in tank. Hope this helps. Thank you.
Jan 15, 2011 | Home
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Mar 01, 2010 | Home
Overheating problem
check the hoses, check the radiator, check the fan, fuse and relays, check the thermostat. check to make sure the head gasket is good, by check for oil and water mixture on the dipstick, same will appears brown
Aug 02, 2009 | 2005 Kia Optima
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,562 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
