Question about Coffee Makers & Espresso Machines
Farberware model 138, base shattered. need base and internal braided cord that attaches to the pots plugs via small nuts.
    Scholar:
  • 176 Answers
You can get the base and the keepwarn element ( braided rope)on eBay under Farberware coffee parts. Ron
Posted on Jul 17, 2010
I am looking for a 2 prong perfect heat control cord for a 3 qt. farberware pot pouring...model no.330 -
Kathy, Try small appliance / repair stores, they can usually get you one or make one.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 05, 2016 | Farberware Coffee Makers & Espresso...
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Jul 23, 2014 | Farberware Coffee Makers & Espresso...
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
FCP-240,280,412 Farberware Percolator, 3 Prong Cord is too heavy for the percolator. It sometimes comes loose and we have cold coffee. Also the Spring on the Pump Tube does not stay in place. Any Help?
HI, on the plug, is it the part that pluges into the wall or the pot. By the model # you have 3 China pots. On the pump just below the coffee basket, take a pair of pliers and put the basket on the tube , now just make small crimp just below the basket,just enough to make it out of round., you will make it so the crimp will not let the spring or basket go by. If it is the plug going into the wall just bend the 2 flat outward so the plug fits snug. Good luck . Ron
Jun 20, 2010 | Coffee Makers & Espresso Machines
Percolator not working
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers.O eBay the KW element is $8.00 and $2.00 S/H. You can BUY-IT-NOW with this auction. Thanks and please ask if you need more help.
Mar 07, 2010 | Salton Farberware& Percolator
I need a leg for a Pot-Pourri electric 5 qt pot.
This leg is interchangeable with the Farberware electric skillet legs. I have a Farberware electric skillet in my eBay store that I'm selling for parts (I have lots of small appliance parts for sale). I could just send you the one leg if you want. Here is the link: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=farberware+electric&submit=Search&_sid=93311479
Feb 12, 2010 | Faberware Kitchen Appliances - Others
Farberware coffee urns not working
Dear Pastor Jim
It sounds like both pots heating elements went out or are going out and need replaced! You didnt give the model numbers so I cant tell you the parts numbers to order! but if you go to the faberware website with the model numbers I am sure they can help you!
This should be an easy fix if you are the handy man type!
Please rate this response
Jan 23, 2009 | Faberware 12-55 Cup Coffee Urn
I need the plastic base for a Faberware FCP 240-A 4 cup Percolato
ok heres a simple fix if you dont have the money for replacement or cant find parts
J.B.weld from auto parts store this stuff if strong enough to fix a cracked engine block so im sure the pot can get fixed this way
Dec 06, 2008 | Faberware FCP240 Coffee Maker
Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Coffee Makers & Espresso Machines Logo
182 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
