Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Blades will not turn so it can freeze the mixture into slushie form , my husband did not check the mixture and it froze into a solid block of ice, took us 3 days to defrost and empty it, now the blades will not rotate, any help for me???
  • Bunn Master
  • 2,237 Answers
There is a sacraficial gear in the gearbox that is strips easy so the motor doesn't get damaged. it'll need to be replaced.
Posted on Sep 10, 2010
  • cdcwax Jul 02, 2011
    Where can you purchase that gear ?
    President:
  • 1,618 Answers
It is possible that the motor that controls the auger drive is damaged, remove the back panel for access.
Posted on Jul 07, 2010
Hi does anyone know anything about the frutina slush machine. Ive just bought a preowned one. Im not sure its working right and it didnt come with instructions. Thankyou
Well I live in Southampton, and Ice Frutina are based here. The liquids come in great big containers that you just pour in ready mixed I think (or perhaps its from concentrate, I'm not sure) but either way the mixing instructions should be on most slushie mix containers. For the machine to make slushie you basically need two things to happen...
1) the powerful refrigerator within the unit should function and chill/freeze the liquid in the hopper
2) The agitator should be constantly turning inside the hopper to break up the ice crystals as they form turning the liquid into slush rather than just a block of solid ice.
If the refrigeration is working, you should notice a pretty quick drop in temperature of the liquid in the hopper... It may be worth checking any fans are working properly and not seized up. Check the refrigerant compressor is humming.
That's about as much as I can help you I'm afraid. Hope it ends up working for you :)
Jan 07, 2017 | The Kitchen Appliances - Others
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Mistral super slushie maker user manual
omg..i jist got a minstral super slushie maker..and man it jist doesnt figure,cant make the slushies..how does it work,,put ice cubes and rock salt and lil water in the ice hole and turned on mix switch and then pored cordial in the back of lid,,all read from the instructions and let spin for 15 minutes,,and nothing three times,,dumb founded,wat the???
Nov 06, 2010 | Microwave Ovens
Parrot ice slushie machine Compressor comes on,
Liquid gets very cold but won't freeze
Jun 10, 2010 | Freezers
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
How can I thaw frozen heater coil hoses?
If your heater core hoses are frozen you should immediately drain the coolant out of your radiator and engine and refill it with the proper mixture. Your lucky if your heater core lines are the only thing that froze, it could have popped a freeze plug or two out of the block. You could use a hair dryer or heat gun if you need to unfreeze it quickly.
Jan 02, 2010 | 2005 Dodge Caravan
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Bravetti ice cream maker problem
Is the mixture being stirred? Enough Ice and salt? Is the mixture correct?
Jun 21, 2009 | Bravetti Triple Treat Ice Cream Maker
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
438 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
