Question about Canon NP 6050 Copier
I HAVE PROBLEMS WITH ON AN READ E901
WHAT E901 MEANS
  • 20 Answers
E901 - Pedestal Motor Signal not generated. Please check the motor diver on the pedestal unit.
Posted on Apr 18, 2008
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
Jun 24, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
My phone does not have any problems, I was just wondering if you could tell me how to remove the envelope from the screen, Thank you
This means you have a text message, look for something that says "messages" and go in and read them all. After you read them or delete them the envelope will go away, if you have problems ask someone to help you find your text messages in your phone.
Sep 02, 2010 | Lands Phones
Automatic page updates causing problems with your
It's means that the new page resolution is too big for your screen. Try the yahoo classic to read your emails.
Mar 03, 2010 | Yahoo Messenger
What causes the check engine light to come on
Any time the car's computer senses a component defect or an operation that occurs outside of specification, it will set the light which means: use a scanner to read any trouble codes that the computer has registered. These codes translate to trouble areas or specific problems. Service shops and dealers charge to read your computer, but auto parts dealers like Autozone will read the computer for free. They will sell you needed parts, but are generally not mechanics. Hope this helps!
Feb 19, 2010 | 2002 Honda Accord
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
Message error E901:press the power switchto off then back to on
cassette feed unit motor or control board are faulty. or something is interfering with it.
Dec 27, 2008 | Canon imageRUNNER 5020 Copier
Check engine light is on.
There are engine codes for alot of diffedent problems. Go to Autozone and have the code read. They will tell you what it means. Post your results, please.
Jul 20, 2008 | 1997 Honda Accord
Canon NP 6050 Copier Logo
102 people viewed this question
old marine
old marine
