Question about Sony KP-46S25 TV
I am Having sony-bigtv of model no: KP-53XBR45 Now
I am Having sony-bigtv of model no: KP-53XBR45 Now I need g-board 1-655-349-14(170984314).I searched this part all over world I didn't found.but I need this part. whether part can be repaired or new one can be found? please give me best solution.
mistersony
  • 320 Answers
SOURCE: KP-57WS520 9 LED blinks
Don't replace the entire G board! that is expensive! The diodes are available from MCM electronics and can be easily replaced.
Posted on Oct 18, 2008
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
  • 178 Answers
SOURCE: sony kp-53xbr45 is bowed and looks 3d convergance
You have a failure in your tv. This is a common failure with many big screen tv's. The convergence driver ic's have failed, they are located on the "D" board in your set. if you want to repair this yourself you need to be aware of the dangers of working inside a televison, even with the tv unplugged from the wall it will still cary voltages that are very dangerous.
There are two approches to the repair that the Technican may use, One approch is to replace the whole "D" board this is the more costly approch, the other approch to the repair is to replace the STK392 ic's and any blowen pic fuses. This repair from a service tech will cost around $300.00 to fix. If you want explisit instructions on how to repair this problem post back and i can get them for you.
Posted on Sep 05, 2009
Testimonial: "Thank you that is better than a new tv"
  • 8457 Answers
SOURCE: arched lines in dark screens
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Posted on Jan 01, 2010
welcomejee
  • 10594 Answers
SOURCE: I need part # for Sony KP-51ws500 D board, and
Required D board part number for KP-51WS500 is appended below:
A1300417A... D COMPLETE BOARD
Available in Part Store, click the link for price info.
Thanks.
Posted on Jun 04, 2010
Need part # KP-53XBR45, convergance IC
The convergence ICs are STK392-010, the locations are IC1601 and IC1602.
Apr 18, 2010 | Sony KP-53XBR45 53" Rear Projection...
Tip
Sony KP-53XBR45 Service Manual Download
Download Sony KP-53XBR45 Service Manual
Would you like to download a free Sony KP-53XBR45 Service Manual?
Have you lost your Sony KP-53XBR45 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-53XBR45 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-53XBR45 Service Manual documentation.
I hope that helps.
___________________________________________
on Jul 04, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 04, 2010 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53XBR45 i have a bad convergence board. Do I fix it or replace it. Where is the part available
Replace convergence out ICs to get it fixed.
You can replace these chips if you can replace parts in circuit board with proper tools or ask local tv tech.
Required ICs are available with Part Store.
Thanks.
Mar 19, 2010 | Sony KP-53XBR45 53" Rear Projection...
Stand by on my sony kp-53xbr tv is blinking steady
That can be caused by lots of different things going wrong. You will not be able to repair that yourself, and will need to have a technician look at that kind of a problem.
Dec 04, 2009 | Sony KP-53XBR45 53" Rear Projection...
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
Sony KP-53XBR45 Bulbs
you can get this bulb at any local electrical shop if you take the sample of your old bulb to show the shopkeeper.also take the take the perfect model number of your tv.
and to check how the board is and how to replace the parts on the boards and many more help please click this link for further help.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sep 24, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53xbr45 problem
on your model which is a RA-1 chassis the power light blinking steady just means the standby voltages are operating, so you will need to trouble shoot the power supply. you will either need the service manual or training manual to trck down the faulty component.
Jun 22, 2008 | Sony KP-53XBR45 53" Rear Projection...
Red light blinkin on the sony kp-53xbr45
Check convergence board for possible blown fuses.
Dec 12, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
