Question about Altec Lansing VS3251 Speaker
I want to know if i can get 5.1 sound on my altec lansing v3251 speakers if i hook it up using the aux. port. i'm using the headphones jack on my laptop.
    Brigadier General:
  • 8,546 Answers
Any analog input will only yield stereo at best. 5.1 is a digital feature.
Posted on Jul 06, 2010
How do Altec Lansing AVS200W 2-Piece Multimedia Speaker System connect to your computer
Using a regular audio cable with 3.5 mm. connectors at both ends, connect your computer to the speaker from the the headphone jack to the 3.5 mm LINE IN jack on the speaker.
Jul 10, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
No sound
Well, i connected my stereo speakers to my computer but i didnt feel like getting the cords so i made my own. i used a cord that uses the headphone jack and used a red and white audio cord for the other end and connected them and it works fine.
Oct 05, 2009 | Altec Lansing ACS 495 Computer Speakers
M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Jun 25, 2009 | Altec Lansing M604 Computer Speakers
Cannot connect my surround sound altec lansing system to my compu
The first thing you can do is go to www.retrevo.com to download the manual. Secondly all you have to do is match the colors of the wires to the imports in the back. You have five speakers. Two have gray wires, two have red and one has blue. If you also notice each speaker has two wires. One a solid color, the other striped with black. For instance, put the solid red wire into the red import and the red wire with the black stripe into the black import. Repeat this with all the other wires. The easiest way to hook it up to your computer or laptop is to take one of the aux wires (the wires with the yellow/green/black tips). It doesn't matter which one. Put into you headphone import on your computer or laptop. Then put the other side into the Aux on the subwoofer. Located on the front. Turn on the power on the back. Then hit the aux button on the remote. That should work....
If you have any other questions or need any more help you can contact me brown.faith@rocketmail.com
Jan 22, 2009 | Altec Lansing VS3251 Speaker
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Altec Lansing VS3251 Speaker Logo
291 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
