Question about Jenn-Air Refrigerators
How do I access light bulbs in my refrigerator Jenn air JRS 227
How do I access both light bulbs in my Jenn aire model JRS refefrigerator?
  • 360 Answers
SOURCE: How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
SOURCE: IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Posted on Mar 15, 2009
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
  • 1891 Answers
SOURCE: REFRIGERATOR REPAIR MANUAL NEEDED
this web sight (fix-ya ) does offer repair manuels I would try it . as for parts info and prices. it will not be in the service . you can also down load this from the web sight .( service maters) from whirlpool . that now has jen air.. hope this has helped you mm feed back pls ..
Posted on Jul 23, 2010
Where is the timer on a Jenn Air Model JRS 228?
Adaptive Defrost Control is located inside the fresh food compartment and behind control panel cover. Part is=> 61005988 Adaptive Defrost Control click here to see location on drawing=> JCB2388G control panel the part #13 in photo is the Adaptive Defrost Control. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Jun 03, 2010 | Jenn-Air JCB2388G Side by Side...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
How do I change the light bulb for my Jenn Air side by side freezer?
the bulb should be about half way up the back
it has a pressure cup cover
pinch it together and it will come off
giving you access to the socket
Oct 14, 2009 | Jenn-Air JCD2389G Side by Side...
Light bulb in door does not work, even with new bulb
Ascertain that you have a bulb designed for your make and model and that even though it may be new, that it does work!
A door switch or connecting wiring could be the cause also.
I have provided a link, courtesy of www.repairclinic.com, to assist you in diagnosing your issue. To access the information you will need to provide the model number off of your unit product ID label. The link below has a guide to help you locate your product ID if you are unable to locate it. Do not supply information from a users manual.
http://www.repairclinic.com/Jenn-Air-Refrigerator-Parts?s=b103a4c253
Aug 20, 2009 | Jenn-Air Refrigerators
How to change the oven light
jenn air usually hides the model number good lol if you open the door on the outer face of the oven might be a little grill where you can see inside and your model might be in there or it might be around the warming drawer if you have one
you need just a regular appliance 20v light bulb you can get at home depot or hARDWARE STORE  if you open the door on the back wall on the left or right upper hand side there is a glass bulb looking object , the material is thick glass/ plastic that just screws off lefty loosy right tighty once that is off you have access to the light bulb
if there is a little wire in front of the thick glass/plastic object just pull it up or down dont unhook it or break it off
Jun 07, 2009 | Ovens
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-air microwave light bulb
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Refrigerators Logo
57 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
