Question about British Telecom BlueProton High-Gain BT3 23dbm Wireless G USB 2.0 802.11g Adapter (BPUSBGHG)
Need driver Blueproton wireless USB for Mac OS 10.4.11
I need a driver for Mac OS 10.4.11 for the BlueProton BT3 wireless USB adapter The included CD only has WIN driver
Need OS X drivers for Netgear WN111 wifi USB adapte. Is there any 3rd party drivers out there?
Clarification Question:
Are asking for Netgear WN111 Wireless USB Adapter for MAC operating system?
Mar 10, 2013 | Computers & Internet
TP-LINK TL-WN727N Driver mac os
As far as I can see from the TP-Link website this adapter is only for PC computers and does not have a mac driver. Sorry.
Nov 14, 2011 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
I want to install alfa awus036h driver
Go to the site
http://www.alfa.com.tw/in/front/bin/ptlist.phtml?Category=105397
and go to usb adapter drivers, download driver for your OS.
Thanks for using FixYa.
May 24, 2011 | OMNI Alfa 500mW AWUS036H USB Wireless...
My cd is broken and can not download setup for my new asus wl-167G wireless usb adapter, copied to a jump drive, but still un able to set up. power mac G5
Please be noted that the adapter is compatible with MAC OS 10.3.X/10.4.X only.
To download the drivers for the adapter please visit the below link:
http://support.asus.com/download.aspx?SLanguage=en&p=11&s=1&m=WL-167g&os=17&hashedid=RuGSPAYDbg4VPynQ
Install the adapter using the above driver.
If you are satisfied with the above information and your problem has been solved, I'd appreciate it if you could accept the answer and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Apr 28, 2011 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Looking for a MAC driver for my F7D4101. The F7D8302 allows MACs to access it, so I bought it's little brother, the F7D4101, thinking I wouldn't have any issues. I need this to work with my MAC, please...
You are trying to install F7D4101 in your mac computer , which is not possible because its not compatible with Mac computers
There is no drivers for the Mac OS for this F7D4101 wireless adapter , its compatible only with Windows XP, Windows Vista, Windows 7
Thanks & Regards,
Prema
Dec 31, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
No drivers
You can download the MAC drivers from the link below:
http://kb.netgear.com/app/answers/detail/a_id/2640
Rate it, if it helps.
Apr 22, 2009 | NetGear WG111 802.11g/b Wireless Adapter
British Telecom BlueProton High-Gain BT3 23dbm Wireless G USB 2.0 802.11g Adapter (BPUSBGHG) Logo
2,170 people viewed this question
Top British Telecom Computers & Internet Experts
David Payne
David Payne
Are you a British Telecom Computer and Internet Expert? Answer questions, earn points and help others
