Question about Sony CDX-GT400 CD Player
Where is fuse located on the unit? - Sony CDX-GT400 CD Player
  • 88 Answers
Under plug, remove the plug of radio and the fuse is here
Posted on Jul 05, 2010
Pyle powered speaker (PPHP123MU) How do you replace the fuse. System completely shut off in middle of use. No power at all. Thanks for any help.
Amp or head unit ? Amp power lead fuse should be located in a holder close to the car battery ,the amp itself will have a fuse as well should be near the terminals where the power and speaker leads are located on the unit , head unit will have a fuse on the wiring harness and a fuse from the main power supply fuse panel in the car.
Nov 06, 2014 | Car Audio & Video
Where are the fuses located in a Goodman Spli type air cond. model# MSG12HRN1W?
They are not generally in the unit. High voltage fuses are usually located in a small box on the side of the house next to the outdoor unit where the electrical line goes in to the unit. The box will have a small door you will have to flip open and there will be a cartridge with two fuses. You can't visibly see a problem with the fuses and if you don't have a ohm meter to check them you will just need to change them both. You might be able to take them to a hardware store and they will check them for you.
The only other fuse is the low voltage fuse generally located on the circuit board of the furnace. If you have a heat pump, there may possibly be a fuse in the outdoor unit circuit board.
May 13, 2011 | Goodman Heating & Cooling
Fuse location for 2000 nissan maxima marker lights
Before you get started, please review this article: Where's The Fuse?
Keeping the information in the article above in mind, the fuse that supplies power to the marker lights is located in the engine compartment fuse block It is fuse# 60. it is a 10 Amp fuse. This fuse supplies power to the Tail Lamp Relay which is located in relay box #1. This relay is controlled by the Auto Light Control Unit, which in turn, is controlled by the main lighting switch.
The Auto Light Control Unit gets its power from fuse #30 (10 Amp) which is located in the Instrument panel fuse block under the left side of the dash.
Mar 26, 2011 | 2000 Nissan Maxima
Heater has stopped working
(1) possible blown fuse.
Note that fuses blow for a reason - seek out the reason, or it will blow its new fuse too.
The main fuse block is located inside the left side of the engine compartment near the battery. There is also an interior fuse panel located just above the left side kick panel.
Interior Fuse Panel
The interior fuses simply unplug from the fuse panel. Use the fuse puller tool provided with your car to remove fuses from the panel. The tool is located on the back of the interior fuse panel cover.
(2) possible blower motor dead. See maintenance manual excerpt below.
(3) possible blower motor relay faulty. Location of Blower relay:
Under hood, drivers side, front engine area,rear of headlight housing; relay mounted on drivers side of radiator shroud.
1990-92 Mazda 626 and MX-6
See Figure below
  1. Disconnect the negative battery cable.
  2. Remove the glove box and the underdash cover.
  3. Detach the electrical connectors from the blower unit.
  4. Remove the blower unit-to-fire wall attaching bolts and remove the blower unit assembly.
  5. Remove the blower motor fan-to-motor fastener.
  6. Remove the blower motor-to-unit attaching bolts, then remove the motor.
  7. Installation is the reverse of the removal procedure.
Feb 01, 2011 | 1991 Mazda 626
Unit will not turn on. Believe fuse is blown. Where is fuse located?
Fuse is located either inline on your hot wire or where you plug in the harness in the back of the unit....Also check cars fuse box for possible blown fuse.
Oct 07, 2010 | JVC KD-LH810 CD Player
Where is the fuse located?
In general you can locate the internal fuse by opening up the microwave cabinet. To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Jun 01, 2010 | Westinghouse WST3504 Microwave Oven
Where is the main fuse?
Hello :
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
The picture bellow is showing a blown fuse .
please rate .
Mar 29, 2010 | Kenmore 80412 Microwave Oven
Where inside are the fuses for the Teac A-6300
if you don't have a fuse holder located on the back of the unit, the fuse or fuses are usually located inside the unit on the circuit board itself close to the main power transformer and / or rectifier assembly.
Mar 14, 2010 | Audio Players & Recorders
230/208 Volt Built-In Room Air Heat/Cool Unit blows cold air, not heat. Unsure if it may be thermostat, if so.. where is it? Another one blew fuse. Where is it located?
To locate the fuse;
1. Turn the power off or unplug the Room Air Heat/Cool unit.
2.Follow the power cord of the unit. This will normally
terminate at the fuse terminal/power reset button., where you can replace the fuse.
3. After the fuse/power reset button terminal the wire
go to a thermostat normally located at the air output
section at the front portion before it goes to the motor
and heating element, while the other wire may connect direct from the fuse terminal to the motor or
heating element.
This is just the basic electrical set up, it can be modi-
fied. Hope this will guide you in locating the fuse and
the thermostat.
fied
Jan 06, 2010 | GE Built-In Room Air Heat Cool Air...
Location of fusebox on 1980 corvette
Fuses are located in the junction box below the instrument panel to the left of the steering column. The turn signal flasher and hazard warning flasher also plug into the fuse block. Each fuse receptacle is marked as to the circuit it protects and the correct amperage of the fuse. In line fuses are also used. Refer to the Fuse Chart at the end of the information for their location. The fuse block on some models is a swing-down unit located in the underside of the instrument panel adjacent to the steering column. Access to the fuse block on some models is gained through the glove box opening. The Convenience Center on some models is a swing-down unit located on the underside of the instrument panel. The swing-down feature provides central location and easy access to buzzers, relays and flasher units. All units are serviced by plug-in replacement. Location of Convenience Center on specific models may vary.
Oct 08, 2009 | 1980 Chevrolet Corvette
Sony CDX-GT400 CD Player Logo
74 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
