Question about Dometic Rooftop RV Air Conditioner
Compressor is blowing breaker, fan comes on. Ac worked fine last season. when trying to go to any cool setting, compressor will actually stall generator, or trip breaker if attached to house
  • 8,404 Answers
You have a faulty start capacitor. The capicitor helps start the motor ... since it is not doing its job, the motor draws LOTS more power from the line popping the breaker. Have your professional RV service center service your AC.
Thanks for your interest in FixYa.com. Please remember to evaluate this response.
Posted on Jul 05, 2010
Testimonial: "I am a technical Instructor for a major import, so I know my way around HVAC. so glad to have someone who can pin point the problem I found that the motor start fuse on top of the capacitor is melted. it still has some continuity, but looks like your diagnosis will fix it."
  • A Miller Jul 28, 2010
    Thanks for the education, the 4 thumbs up. I am happy to hear you are on your way to getting this AC going.
    /s/ me ... just a guy with a little bit of a/c knowledge
    President:
  • 1,515 Answers
Hi, just some food for thought, it is a run capacitor, not a start. The capacitor has a resister across it that has over heated. The first thing to check would be the capacitor, but if the compressor is drawing enough amperage to kill the generator, I would also mega ohm the compressor windings as this may also cause this problem. Some older compressors had the start capacitor, then they added a run so the start would drop out when the compressor got up to speed. Now, they did away with most all start capacitors except on refrigeration equip. They use both single and dual capacitors on a/c units. Good answer though.
Sincerely,
Shastalaker7
A/C, Heating, and Refrigeration Contractor
Posted on Jul 10, 2010
  • Robert Horton
    Robert Horton Jul 12, 2010
    Thank you for the great rating, please look me up if you need any more information.
    Sincerely,
    Shastalaker7, A/C, Heating, & Refrigeration Contractor
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
AC is just blowing air. The compressor doesn't kick on.
no freon.. pressure test w/ nitrogen. 8000 btus is now junk. Spend the money on new unit otherwise find the leak. It leaked out thats why the compressor will never go on. Once you add freon she'll turn on...same as car.
Dont buy that name brand again. best of luck to you
Aug 17, 2009 | LG Heat cool Window Air Conditioner
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Air conditioner not cooling
You can't tell if you have a refrigerant leak unless you put gauges on. You may not have any sign of a leak and still be out.
Mar 31, 2009 | Goldstar Heating & Cooling
Window AC support
Not that I'm an A/C guy but sounds like the compressor motor is toast. It's building too much resistance and tripping the breaker...FYI make sure you unplug it...you don't want your house to burn down while you're sleeping or at work. good luck
Aug 28, 2007 | Kenmore 72055 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
504 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
