Question about HP Photosmart 7450 InkJet Printer
PAPER JAM The paper jams and then the ink cartridge won,t move. The printer has been turned off and back on, the computer has been turned off, then back on. I've been trying to delete the printer software and that's not happening.......has Vista.
    President:
  • 1,561 Answers
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly, The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jamIf the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Take care.
Posted on Jul 05, 2010
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
I HAVE A PIECE OF PHOTO PAPER STUCK AND IT WON'T MOVE WHAT CAN I DO
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
Step 8
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Lexmark X2600 InkJet Printer
Message says; Paper jam. There is no paper in it. Tried turning off and back on, resetting. Nothing, same message. Any ideas? Thanks, Niki
Open the back door and look in the middle of the back cover, there's a black plastic sensor lever that must move up and down freely as the paper passes. That lever gets sticky and needs to be cleaned with alcohol so it can move freely again. You may need to remove the back cover with 2 phillips screws to gain access.
Please rate my response!!
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper Jam lite is on ( no paper jam )
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 28, 2009 | Brother HL-2040 Laser Printer
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
alternative :
Mar 27, 2009 | HP Photosmart C5280 Printer
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
Jan 05, 2009 | HP LaserJet M3027 MFP Printer
Paper Jam
try this
alternative :
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Printer cartridges not moving
Try turning the printer off and unplugging it both from the wall and from the computer. Take the paper out.
Open the paper jam door and gently push the paper roller forward or upward until it clicks. Close the paper jam door.
Leave the printer unplugged for several minutes (15). Then plug it back in. Do not turn it back on yet and restart your computer. then turn on your printer.
I hope this reset works for you. You may have to do it more than once. I've been through this one myself.
Thank you for using Fix Ya! Your ratings are always appreciated.
Aug 24, 2008 | HP DeskJet 5550 InkJet Printer
Paper jam
give this a shot
alternative :
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
HP Photosmart 7450 InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
