Question about Ryobi Factory-Reconditioned 30cc 18" Gas Hedge Trimmer ZRRY30550
My TP30 Ryobi weed eater turns and stays on while
Tp30 weed eater turns off after primer bulb runs out of fuel. You can reprime fuel bulb and it turns on right away. I don't know what can be causing it to turn off.
    Problem Solver:
  • 14 Answers
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Posted on Jul 07, 2010
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
What else should i try
Make sure lines are connected correctly. On the back of primer it is stamped In & out
Jul 25, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Jul 10, 2010 | Craftsman Garden
I have a ryoby 31cc weed eater I need a diagrm on the corect posision of fuel lines
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need part for ryobi tp-30 pole saw
ill sell you a tp30 that has under 100 hrs on it. only needs carb adjusted dont have tool $125
Mar 23, 2009 | Ryobi Garden
Ryobi Factory-Reconditioned  30cc 18" Gas Hedge Trimmer ZRRY30550 Logo
591 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
