Question about Kitchen Ranges
One of the elements on my cooktop runs red hot regardless of the temp setting
  • 145 Answers
Sounds like you have a switch problem. The switch controls how much power goes to the element. Disconnect power before changing the switch.
Posted on Apr 18, 2008
How to wire element
check the link it might help. Usually the Red or Blacks are Hot or Line the Tan and yellows are the heat range Lines for the inner and outer coil 03 Wiring Information Parts for Jenn Air JEC8430ADS
Dec 04, 2013 | Maytag MEC5430 Electric Cooktop
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
If it does not smoke?
First make sure you have power. If the digital control unit lights up and you can set temp and time, put the temp at the highest setting. Wait until the red light turns on wait a few minutes. Check the element, it should be glowing cherry red. If it doesn
t get red hot then the element is bad or there is a bad wire that is broken or shorted out. Good Luck
Mar 07, 2010 | Masterbuilt ESQ30B Smoker
Oven heats very slowly (Jenn-Air JGS9900BDS). Cooktop works fine. Broiler works. No error codes.
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Jul 08, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
