Question about Craftsman 25cc Gas Line Trimmer
How do change the line? can not get head off Craftsman 25cc Gas Line Trimmer
    Problem Solver:
  • 14 Answers
Should be a button on side of head assembly. press in and top should come off
Posted on Jul 05, 2010
  • Thejaguar14 May 12, 2011
    NO. Im pretty sure you have to take the wire Carlback and then the two tension holes near the center of the head you push into, then the center piece should have a round disk just .275 cm above which you grab, (Twist and Turn) , and at that point, the top peice should be to be removable.
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
How do you replace the trimmer head on the Craftsman 27cc trimmer (Model 711170)?
U-tube has some good videos on all sorts of replacements on heads , lines...etc.
May 13, 2014 | Craftsman Convertible 25cc. Gas Line...
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
How do I get more line to come out of my craftsman trimmer model 316.79190?
Maybe try going to : www.searspartsdirect.com and download your model specific user manual. They probably have detailed instructions in there on the operation of your string head.
Aug 25, 2010 | Craftsman 25cc Gas Line Trimmer
Need ratio for craftsman gas line trimmer
i think the mixture is 50:1 50 petrol and 1 oil
Jul 21, 2010 | Craftsman 25cc Gas Line Trimmer
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Adjusting the carburator on a craftsman 25cc line trimmer
Replace all of the lines before any adjustments, too small to see air leaks are a common cause the issue you have.
Feb 27, 2010 | Craftsman 25cc Gas Line Trimmer
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
547 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
