Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Dishes do not get clean.
After a cycle, the dishes and contents have to be re-washed by hand. I have tried cleaning out the spray holes, but has not solved the problem.
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
Spots are left on the dishes after washing. Dishes don't look clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Dishwasher is not cleaning dishes
i would suspect spraying arms or water temp not working.adrian,,,
Jul 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap left in dispenser after wash cycle
Probably blocked spray arms is the cause of the unit not cleaning the dishes properly and also not removing all the detergent from the dispenser. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Also make sure you are only using about 2 teaspoons of detergent. you may just be using too much.
Jan 25, 2010 | Kenmore Dishwashers
After washing cycle dishes do have not been rinsed
Not Rincing properly normally referrs to a few things to check. 1)remove both rotors and clean holes properly. Once dishes have been stacked make sure the rotors can turn freely. Try now. Suggest you clean the sieve on the incomming water pipe.(at the valve.)
Sep 21, 2009 | Whirlpool Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
CANT USE FAIRLY NEW WHIRLPOOL STAINLESS DISHWASHER
Check and inspect spray arms to see if they are clean especially at the ends there is a small hole at each end which needs to be clear to turn spray arm. Addition, Make sure water is sufficient in basin after fill.Well water could clock fill valve. Consider gel instead of powder if water is hard.Thank you
May 29, 2009 | Dishwashers
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
