Question about Refrigerators
I have a domestic rm2652 rv frig and everytime it tries to start it kicks the breaker. (ground fault type breaker) I have not tried gas yet.
  • Refrigerators Master
  • 3,083 Answers
Others have had this problem, I found, after looking around on the net. Here is an excellent blog about the problem, and it contains wiring diagrams and suggestions for what might be going on. It contains more and better advice than I could give, or guess at. Here's the blog:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24009414/gotomsg/24010212.cfm
One thing you might check first, is to make sure the 12 v power is not reversed. If it is, a heavy duty diode will trip the breaker- so check that first. Read the blog over and see if they can help you run this problem down. It could also be a problem with your wiring shorting out, and they have suggestions about figuring it out. Good luck, and hope this helps!
Posted on Jul 05, 2010
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Dometic RM2652 Refrigerator
Action 1: My RM2652 runs well on auto mode when its indicator's light is lit. Auto mode is an electric mode, right? Action 2: When I press on the "gas" button, the indicator's light next to the "auto"...
Auto mode is electric 1st then gas. If no 110v is available it tries to light the gas. Do you have gas & is it turned on? You should hear a clicking from the back of the frig. Make sure the air is purged out of the system by lighting your range and let the burners come on for 30 sec or so. You might have to cycle the frig on & off a couple of times after you purge the air. Set the button to "gas only".
Apr 01, 2010 | Dometic RM2652 Refrigerator
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Recall
just go ton google search type in your model # and it will bring you to arizona salvage which lists a;; recalls. Also lists 1-800-#
Sep 08, 2008 | Dometic RM2652 Refrigerator
Circut Breaker trips
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Jul 08, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
