Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dirty water in the strainer sump after cycle is complete. I find it hard to believe that this is normal operation. Why would final rinse water be still cloudy? The strainer sump always has about a cup of cloudy water with particulates in it after each load is complete. I clean the strainer after each load and I scrape or rinse plates prior to loading. It's as though the machine never really drains the sump during cycles. Same behavior with both drawers. The dishes and glassware always come out looking great, but I'm grossed out by the fact that they were final-rinsed by such unclean-looking water. Any ideas other than crummy design?
  • Fisher and P... Master
  • 3,247 Answers
The drain outlet in your sink is not clean. If you use inkserator then make sure it has been run and the sink drain is clear.
Posted on Jul 30, 2010
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Cant get the cleaning cycle to end dont know how to get it off
If the red light is still blinking, then the cleaning cycle has not yet been completed. The cleaning cycle is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 07, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
Our dishes are coming out partially dirty with a layer of soap scum on them. We have tried three different types of soap and nothing is helping.
Hi
Daniel
Jan 07, 2011 | Frigidaire 24 in. FDB635RF Built-in...
My dishwasher is cleaning plates but the glasses up top are coming out dirty like smokey looking please help
Hi
Daniel
Oct 26, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
As it started through the rinse cycle, it stopped and flashed error codes (H and F I believe). The door locked button is lit and I've tried all the normal suggested ways to get the door unlocked, to no...
f h means no water check your cold water line make sure the strainer is clean .will be at the back of washer where hose connect. to clear this hit pause/cancel twice
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher rinsing with dirty water-help
Now is a good time to remove the spray arm and the filter/strainer underneath it. Clean everything you remove in the sink. With a flashlight, inspect everywhere in the sump area and remove debris (watch out for broken glass!) Inspect the impeller, making sure it is not broken and that is spins freely. While you are in there, look carefully at the heating element for damage and breaks.
Reassemble and test. If it continues to leave a film on the dishes (especially visible on the glassware) suspect the heating element (no kidding) If it is not heating during the final rinse and drying cycle, that is your main problem.
If problems continue when the heating element is working, then the wash motor is failing and needs to be replaced.
Good Luck, please post back here with what you find, OK?
Apr 11, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
Cloudy glasses with hard white calcium build-up
the problem is not your dishwasher or your detergent. the reason for these spots is hard water. www.dishwasherfilter.com makes a new product to address and fix this problem. it filters the water going into your dishwasher leaving your dishes spot free with every load. it is very affordable and fits right under your sink. it is guaranteed to work or your money back. you will love this product. thanks
Apr 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Feb 10, 2009 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
135 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
