Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Homelite UT20811 plug type gap. Have fuel. Intermittent spark. Runs 15 sec shuts down no spark.
3 Suggested Answers
slohry
  • 87 Answers
SOURCE: WHAT IS THE SPARK GAP ON 25CC HOMELITE WEEDEATER
Gap is set to .030
Posted on Apr 11, 2009
panilling9
  • 284 Answers
SOURCE: spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Posted on Jul 05, 2009
What is the spark plug gap for a homelite BP 250 gas blower
Not sure of the book value but I always use .025 to .028 gap on the plug and it runs fine. Hope this helps.
Jun 30, 2015 | Homelite Garden
I have an old homelite super xl saw and what i need to know is the high and low adjustments as well as spark plug gap
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Jul 15, 2011 | Homelite Garden
2004 softail runs ok low rpms mid rpm runs like **** high rpms runs ok I checked the insude fuel lines found a pin hole in the down ward line going to the bottom of the tank and replaced it i thought that...
Hi W_orth, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Dec 19, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Oil Leak
When the saw shuts itself off, remove the spark plug and check for blue, snappy spark with a fresh/clean plug set at 0.020" gap. If nothing, remove the flywheel cover to expose the wheel and ignition module. Remove the ignition switch wire and try for spark, if still nothing, check the pole gap at the module with a thin business card. Bring the flywheel magnets under the module poles, insert the card into the existing gap, loosen the mounting screws to allow the module to contact the module poles, then tighten the screws. Rotate the wheel somewhat to remove the card, and try for spark again. If still nothing, replace the module and install as above. Don't forget the ignition switch wire. If the first test gave good spark, put some fuel mix into the plug hole and try for start--it should pop several times. If ok, release the fuel cap for a moment and see if restart can be done. If it does, then clean the vent area on the tank side (a small bronze plate in the tank case). Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Does the primer pump pull fresh fuel into itself when pumped several times? If not, remove the carburetor and clean it inside and out with spray carburetor cleaner. Check the lower chamber diaphragm for flexibility with no holes or cracks. Hope some of this gets you running!
May 30, 2010 | Homelite ZR10926 16" Chain Saw
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Starts dificult; runs for 30 sec then shuts off abruptly
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
Jan 30, 2010 | Homelite Garden
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
146 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
