Question about NetGear WGR614 Wireless Router
Netgear WGR614 Wireless Router what do i need to
Netgear WGR614 Wireless Router what do i need to use this signal up to 12 blocks away.
  • 8,404 Answers
Theoretical covrage is 600 feet ... 300 on each side of the antenna ... provided there are no walls, no trees, no cars etc. between you and the antenna. If you want to go further, you will have to get a 'bridge' and commercial grade repeaters/antennas which may transmit as far as 1000 feet or you may want to get high power equipment that will transmit further ...
How big are your 'blocks'? Trees? Buildings? EMI in the area?
Posted on Jul 05, 2010
I need a power adapter for a netgear WGR614 wireless router. what is the output? 12v or 9v?
Most Netgear wireless routers use 12 volt power adapters. The label on the Netgear shows the voltage input required.
Mar 19, 2011 | NetGear WGR614 Router
My netgear wgr614 router quit working. no lights are on, no signal. any advice?????
First check the power supply and where it's plugged into. Power strip breaker? plastic block fell out of outlet?
If you have a meter, check that you're getting 5 volts or more at the end you plug into the router. You could fudge it with a peice of wire and a flashlight bulb. If it lights up bright, at all, then it's putting out juice. If router still no lights, toss it. It's dead.
You'll need a new one.
Sorry
Feb 03, 2011 | NetGear WGR614 Wireless Router
We have high speed internet service with a netgear WGR614 connected for wireless service... I keep losing connection and the PC attempts to automatically reconnect, any help? Thanks.
Make sure the latest wireless card driver is installed in the computer.
Locate the wireless router higher and away from walls. Locate the wireless router away from cordless phones and microwave ovens these can cause interference.
You could be getting interference from other wireless access points or wireless routers in your area. Check the wireless broadcast channels in your area, and select one that is unused or one that has the weakest signal strength.
Dec 19, 2009 | NetGear WGR614 Wireless Router
Netgear wireless router wgr614 not transmitting
Yes changing channel will make a diffeence most of the time for this kind of issue. The reason is there could be multiple routers or interference in that area locking to the same frequency.
Aug 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Aquiring Network Connection over and over. RAWR
How many DHCP devices are there on the network?
There should be only one. Try disabling the DHCP in your device, then your neighbours router should issue IP addresses and all will be ok.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Using a Netgear wireless-G router wgr614 with an Actiontec GT704W
Try to avoid the breaker box and furnace as mutch as posible. Also you could try both computers wireless and put the router on first floor.
Mar 14, 2009 | NetGear WGR614 Wireless Router
Low signal (amber Light0
restrt your wireless router.
Jan 03, 2009 | NetGear WGR614 Wireless Router
Wireless
There are several ways to boost the signal from your router. One, you could try moving it to a central location of the house..the more walls and obstacles, the worse the signal. Try moving any cordless phones away from due to the wireless phones transmitting on the same frequency causing interference. You could also purchase a repeater from an electronics store..I believe AirLink makes one. These devices intercept the original signal and act as a booster..you would try to center this device in your home as well. You could also purchase a better antenna for your router with a higher gain output. Just some suggestions.
Good Luck
Jul 01, 2008 | NetGear WGR614 Wireless Router
Netgear WGR614 router
Hi supermosang .
Have you check the new firmaware update for your Netgear? ..pls do so first before proceeding to the next step provided below.
Next approach is to unistall and reinstall you 'reciever' to avoid any conflicts and isolate the issue. If that step is still a no go we might as well reset your netgear router to its factory settings and then lets start from there. It should work as your router has fanstastic features that supports 26bit encryption.
Good Luck.
Jun 11, 2008 | NetGear WGR614 Wireless Router
NETGEAR WIRELESS
More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
Jan 17, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
172 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
