Question about Pentax *ist DL Digital Camera
Broken door to battery compartment
Require replacement door to battery compartment
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Here's a possible source, though I'd check to see whether the battery covers for the ist and the *ist are the same.
http://uscamera.com/istd.htm
Posted on Jul 05, 2010
Bull Safe with two doors and 3 door front load. Battery compartment on both doors are broken. Currently held by tape. Is it possible to order a replacement cover to hold the batteries securely?
You should be able to purchase replacement parts..Check your manufacturers Website /support page ..and check eBay also . Good luck
Nov 16, 2016 | Cameras
How to replace the door blend actuator on 2009 lincoln mks
Right side or left ? Electronic Automatic Temperature Control or manual ? Temperature or mode door ?
Temperature Blend Door Actuator - LH Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
  1. Remove the 2 lower steering column opening cover bolts.
  1. Detach the lower steering column opening cover.
  1. Disconnect the in-vehicle temperature sensor aspirator hose and electrical connector.
  1. Position the instrument panel wire harness away from the LH temperature blend door actuator.
  1. Remove the 3 LH temperature blend door actuator screws.
  1. Disconnect the LH temperature blend door actuator electrical connector.
  1. Remove the LH temperature blend door actuator.
  1. Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
Temperature Blend Door Actuator - RH, Dual-Zone EATC Removal and Installation
NOTE: It is not required to install the new RH temperature blend door linkage parts included in the RH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
RH temperature blend door actuator and linkage
  1. Disconnect the glove compartment damper from the glove compartment.
  1. Remove the glove compartment.
  1. Remove the RH lower instrument panel insulator.
  1. Remove the RH lower floor console trim panel.
  1. Remove the 3 RH temperature blend door actuator screws.
  1. Disconnect the RH temperature blend door actuator electrical connector.
  1. Remove the RH temperature blend door actuator.
  1. Manually operate, and inspect the RH temperature blend door linkage for incorrect placement, binding or damage.
  2. Mode Door Actuator - Defrost/Panel/Floor Door
  3. Removal and Installation
    NOTE: The defrost/panel/floor mode door actuator can be accessed from below the driver side of the instrument panel.
    NOTE: It is not required to install the new defrost/panel/floor mode door linkage parts included in the defrost/panel/floor mode door actuator service part kit if only the mode door actuator requires replacement and the linkage parts are not broken or binding.
    Mode door actuator and linkage
    1. Remove the 3 defrost/panel/floor mode door actuator screws.
    1. Disconnect the defrost/panel/floor mode door actuator electrical connector.
    1. Remove the defrost/panel/floor mode door actuator.
    1. Manually operate, and inspect the defrost/panel/floor mode door linkage for incorrect placement or damage.
    Mode door actuator linkage only
    1. Remove the mode door linkage.
      1. Depress the tab and remove the panel door lever.
      1. Remove the floor/defrost door intermediate lever screw and floor/defrost door intermediate lever.
      1. Pull straight outward to remove the floor/defrost door lever.
    1. NOTE: When installing the mode door actuator, make sure that the panel door lever and floor/defrost intermediate lever are correctly aligned with the mode door actuator cam.
      To install, reverse the removal procedure.
Nov 10, 2016 | 2009 Lincoln MKS
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
FE-140 Battery compartment door broken
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Pentax *ist DL Digital Camera Logo
100 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
