Question about Gateway DMP300 (256 MB) MP3 Player
I have a napa 1gb lcd mp3 player and i can't find the reset button
I want software for t.sonic610 1gb mp3 player.please assist me
my i pod is hang some time and after some min its autometically soutdown evan my battry is full.
Aug 20, 2009 | Transcend T.sonic 610 MP3 Player
Trancend mp3 player t.sonic 610 1gb
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "play" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Apr 01, 2009 | Transcend T SONIC 630 MP3 Player
Problem in reading files
i have problem with my T.sonic 610 1GB Mp3 player. after storing the files the player is not able to read the files. it simply shows ***no files***. the fm player is working normally. even after pressin the reset there is no use.I Press power on button again & again ON/OFF please tell me how to deal with this.
Ashish
Nov 06, 2008 | Transcend T-Sonic 840 MP3 Player
Craig mp3 1gb player cmp580d
this is a no brainer.....first thing I did was set up (formatted) the player with the disk drive utility supplied with mp3 player. Next you add in your MP3 songs. Turn on your player and with the mode button...go to MSC it will be highlighted black....then press in mode button to enter folder. Songs shouls be seen....and press power button to start.
May 15, 2008 | Audio Players & Recorders
Please help!!!
1 Other User Has The Same Problem Posted by DEEDEE0809 on May 06, 2008I HAVE A SANSA SANDISK 1GB AND I HAVE FULLY CHARGED
IT AND I WOULD LIKE TO KNOW HOW I RESET IT
You can do a hard reset by pressing and holding down the Select button (it's a silver square on mine) while pressing the volume + and - buttons simultaneously once.
Let me know if this helps. It didn't seem to fix my problem!
Apr 24, 2008 | SanDisk Sansa MP3 Player
Cannot unlock it
The hold button is activated. The hold button stops buttons accidently being pressed when the player is being used during sport or exercise.
Slide the hold button towards the RESET button hole in the side of the casing.
Feb 11, 2008 | Philips GoGear SA178 MP3 Player
My mp3 player just stop working
I had the same problem... I tried pressing the reset with a pen but didn't get any response... so I unwound a paper clip and actually heard an audible click when it reset... then it powered right back up... yay!!
Jan 18, 2008 | GPX MW3837 MP3 Player
Mp3 player philips
you have to unlock it i had the same prob : let th back of your mp3 face the floor andon the right you will see a button near the reset **** that button and turn it on
Oct 08, 2007 | Philips SA4010 MP3 Player
Memoryproblem
Try creating a new or extended partition in the unused space using a later version of Partition Magic (www.download.com)This problem usually occurs due to a previous format not completing correctly IE the MP3 player was removed from the USB source before completing a previous format. Check to see that there is not a pinhole reset button on your MP3 player (requiring a paperclip or pen to be inserted into the pinhole and pressed until a factory reset of the device completes) Much like resetting a digital watch)once reset to factory you can attempt to format the device fully again.
May 17, 2007 | Sony NW-E405 MP3 Player
Gateway DMP300 (256 MB) MP3 Player Logo
129 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
