MY DELL INSPIRON 5160 HAVE THE BAT AND STANDBY LIGHTS ON THE FRONT FLASHING (CONNECTED TO POWER WITHOUT BAT) AND DONT BOOT ,WHAT CAN I DO ?
  • RUI MOREIRA
    RUI MOREIRA Jul 06, 2010
    thanks helps a lot
    President:
  • 4,070 Answers
Hi! Please try this... unplug the laptop from power source and remove the battery. Press hold the power button for 10secs. to drain out stored power. After doing so just let it sit for 30mins. then insert the battery. Turn on the laptop and see how it goes. Hope this helps and have a good one!
Posted on Jul 05, 2010
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
When booting up the computer, the screen "flashes"
If the monitor works try hit ctrl alt f3. if that works you might have to reset your resolution
Jan 18, 2011 | Dell Inspiron 5160 Notebook
I have a dell inspiron 5160 and the batery light and the power light is flashing at the same time what will cause this to do that
Hi there, I would like to try and help you solve this, please let me know if you replaced your motherboard. Is your computer turning on?
May 26, 2010 | Dell Inspiron 5160 Notebook
I have a dell inspiron 5160 that is stuck in standby mode i even switched out the battery how do i get it out of standby
Usually just before it come on hit the F10 Button then follow instructions to go back to regular mode.
Aug 17, 2009 | Dell Computers & Internet
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Jul 14, 2008 | Dell Inspiron 5160 Notebook
My Dell Inspiron 1150 PC Notebook Won't Turn On
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Jan 15, 2008 | Dell Inspiron 1150 Notebook
My Dell Inspiron 5160 won t turn on
Hello viceaddict6,
That model is known for this problem and Dell is aware of it. I believe they will replace your motherboard and AC adapter free of charge. Tell them your problem with the lights, and that motherboard is most likely not getting the powere it needs.
Below is the information to contact them; they are open 24/7. The express code they are referring to is a sticker that is taped to the laptop. My personal experience with them is good, they usually have someone drive out or come by within the same day or next day and replace the hardware with a smile.
Technical Support
(Please have your Express Service Code ready when calling) 1-800-624-9896
Regards,
Chester
Jan 12, 2008 | Dell (0N5370) for Inspiron 5160 (64MB) (64...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
