Question about Earthquake Sound PH-D2 Car Audio Amplifier
Problem with Eathquake amp 2000w
I am currently running 2 15'in cvr kickers off of a 2000 w earthquake amp, the amp has an auto function to turn off when i am guessing over heated or something. To override the amp's security shut off, you have to restart the battery. Which I did my turning my truck off and on again. I now understand that it was turning off to protect it self. I may have fried the internal battery on the amp. It refuses to power the subs anymore, the power light to the amp is on. Its running through a 1.5 farad compacitor. Does anyone have any input of suggestions on how i would go about trouble-shooting, or even just getting it to work again.? thanks
  • 24 Answers
The amp dose not have any such internal batery it is probly tosted call me 256-698-9903
Posted on Jul 08, 2010
Can I wire a 2ohm Kicker CVR with a 4ohm Kicker CVR to a monoblock amp 1 channel
yes. google, impedance calculator and it will help you out on how to wire it
Apr 12, 2015 | Kicker Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
Amp gets hot and shuts down
Time for a bigger amp or better wiring to the amp. You can try a cooling fan setup to cool the amp. Brushless computer fans work pretty good, draw very little current and move quite a bit of air and they're really cheap to buy.
Dec 18, 2013 | Kicker Car Audio & Video
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
Can i run 4 dual 2 ohm cvr 12's on a kicker 1500.1 mono block amp
Yes you can if you run them each as 4ohms. Running them at 1ohms will most likely overload the amp.
Apr 13, 2011 | Kicker CVR12 Car Subwoofer
I have two Kicker dvc cvr's 12's and I want to hook them up to a Kenwood KAC-520 1000 watt amp. Whats the best wiring to wire these?
The best thing to do would be to get an amp installation kit, at an auto stereo store or Wal-Mart automotive department. It will have the wiring and connects that you'll need to wire everything up.
May 19, 2010 | Car Audio & Video
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Earthquake Sound PH-D2 Car Audio Amplifier Logo
102 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
xxxxxx xxx
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
