Question about Intel Motherboard
How to get power reset to onboard? - Intel Motherboard
  • 8,404 Answers
Remove the battery from the mother board ... wait 30 secocnds ... put it back in ... plug all cords and cables back into the computer.
Posted on Jul 05, 2010
NO ONBOARD VIDEO
Hello here is the ASUS homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N73-AM&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
I have the same problem with Asrock ALiveNF7G-HD720p motherboard with Gigabyte nVidia 8400GS video PCI adapter, it sometimes work but most of the time boot to onboard motherboard even though the BIOS...
You would want to make sure you have the latest bios for the motherboard updated. If the issue happens during post then it would be a motherboard related. However if it only happens in windows it would be an issue with the drives. Try grabbing the latest drivers from NVIDIA's website for your card. Then go into device manager in Windows and make sure you right click the onboard video and disable it. This setting should disable the onboard video in Windows and only allow the 8400GS card to run.
Feb 26, 2011 | Gigabyte Computers & Internet
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Regards.
Jun 28, 2010 | PC Chips Computers & Internet
Hi please help my son has set his computer to onboard graphics but he does not have any he has a pci card now he cant get a picture on his monitor how can i reset his card
Reset the CMOS configuration; remove the on-board battery (lithium coin cell) for about 5 minutes, then put back in and power up. Enter the BIOS to reset time, date etc.
Jun 17, 2010 | HP Computers & Internet
Power on password wont allow me in
Call HP and prove to them you're the rightful owner and maybe they can help you. This is a feature to prevent someone stealing you pc and using it. Sorry this is the solution.
Jun 13, 2009 | HP Compaq nx6325 Notebook
VGA
It can do give it a try I have never had trouble doing this if not
go into BIOS and reset video
Aug 15, 2008 | Mach Speed (PM9MS) Motherboard
Omg msi 2600+ ....how to reset bios?
Replace the cell and the reset your bios settings it will work for you .
Mar 09, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
Loss of power to onboard USB and PS2 ports
Hi, I checked a known good spare motherboard with a VOM (continuity tester): pin 4 of the KB PS2 port, pin 1 of the rear USB, pin 1 & 2 of the front panel USB onboard connector, pin 3 of the infrared, pin 4 of the speaker connector, pins 4, 6,21 & 22 of the ATX 24-pin Power Connector are all interconnected (+5VDC). If that is an indication of the general +5 supply layout, you can probably hard wire a new +5 supply line to where the +5 is gone from where it is still available. Of course without a schematic, I might be off. Determining the actual component position of the surface mounted fuse (or fusible link) might not be that easy since manufacturer do not publish such information loosely. A shotgun approach (test all) would be time consuming but of course challenging. Your best bet would probably be as mentioned earlier, hardwire and install in series with the new +5 line a low amp (500ma or lower) smfuse. This article describes the power requirement of USB ports > http://pinouts.ru/Slots/USB_pinout.shtml. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 18, 2007 | MSI MBOX PM8M2-V (MBOXPM8M2V) Barebone
Intel Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
