Question about Saws
My belt keeps jumping off when I'm using the saw
  • 8,404 Answers
Is the blade and motor aligned correctly? Motor loose? Is the belt tight?
Posted on Jul 05, 2010
Belt keeps jumping off the front pully
need to know make, model ,year of the chain saw that has a front pulley and a clutch
photos would be a big help in your next post
you are in the chainsaws catagory
Sep 02, 2016 | Garden
Why the traction belt keeps jumping off the pump pulley
If it is an old belt, replace it. Also make sure all pulleys are tight and belt is in all of the belt guides.
May 20, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Why does my blade keep jumping off track on my black and decker 7 1/2 band saw
There are few reasons why blade jumps off, you may have a poor weld on the blade. Tension could be too tight or too loose. Make sure that the blade tracks properly. I advise you to watch videos about tuning up a band saw or check some informative blogs on bandsawblog.com. I purchased my blades on sawblade.com , check them out if you need any.
May 14, 2014 | Saws
New serpentine belt keeps jumping off
Hi Daniel,Sounds like your belt tensioner is bad and not keeping proper tension on belt,Here is a picture of the belt tensioner,and here's your belt diagram.
Feb 01, 2013 | 1989 GMC Sierra
Jig saw catching and jumping using new vermont american blades
try one with more teeth and do not force it into the wood
May 14, 2012 | Vermont American Tool Company Saws
Belt jumps off on start up..no problems until it was transported to another location..what should I check
Look for adjustment for tensioning belt. The motor is probably mounted on a sliding bracket arrangement which came loose during transport slackening the belt.
Nov 30, 2010 | Ridgid Heavy Duty 10" Portable Table Saw...
Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Apr 15, 2010 | Wilton 5" X 8" Dry Horizontal Bandsaw Band...
I'm up to where you have to scare jimbo of the ufo
Hello! uh its rayher easy really you need to climb a rocky kinda surface and jump to these things poking out the ground that blow air upwards the once up there take a big run up and once at the edge JUMP! then quickly get to the platform before you get knocked off. let Homer up and then jump onto the see-saw-as homer to way it down change back to bart and jump off the high point of the see-saw onto the middle part(big thing jimbo's in) then jump jump jump and your at jimbo!!
Jan 13, 2009 | EA - Electronic Arts The Simpsons Game for...
Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Nov 17, 2008 | Saws
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
