Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
My hf205 monitor make pictures oblong. A large circle in elongated and flattened slightly. The pix fills the screen and the display setting is for 1024*768 resolution. Everything else seems ok.
    Problem Solver:
  • 17 Answers
PLS LOAD YOU YOUR MONITOR DRIVER CD.
Posted on Jul 06, 2010
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wide screen stretches all my photos
Dec 09, 2011 | Samsung Computers & Internet
The images on the monitor are stretched lateraly
Depending upon the screen resolution that has been set in Display, the image will be distorted on these wide screen monitors.
Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle. When you are satisfied then click apply.
Feb 24, 2011 | LG W2053TQPF 20 inch Monitor
Everything is distorted and elongated
You need to set the PC video resolution to the native resolution of this monitor, 1920 x 1080 @ 60Hz for best picture and correct aspect ratio.
You may have to load the driver if you cannot get the PC the let you select this resolution.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Acer X233H 23" Monitor
I have a new flat screen monitor, thats oblong in shape and my eyes are going nuts because its all stretched out and i want it square looking.how can i change it?
This is common with wide screens and the screen resolution needs to be adjusted to keep the correct aspect ratio.
My method, open MS Word - new document then Click on Insert - Picture - Autoshape and select a circle and place this shape in the document. Then if you wish to make the shape larger, then hold down the Shift key and drag the corner box to make the shape larger.
NOTE by holding down the Shift key, the circle will keep its shape and not distort.
Now Click on Control panel - Display - Settings and adjust the screen resolution and then view the Word doc with the circle, if it is not a perfect circle then, adjust the screen resolution again until you see a perfect circle. I suggest you start at the highest resolution that suits you and work down.
Mar 21, 2010 | Compaq Computers & Internet
How to alter the geometry of an Acer AL1715 monitor. Circles are oval, elongated vertically
Go to Start, Control Panel, Display, Settings. Select screen resolution. Don't pick as wide of a screen.
Apr 02, 2009 | Acer Computers & Internet
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
692 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
