Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Older model R71-305 Rheem Electric Water Heater
I need to replace the heater elements. The only access panel is on the bottom but there's also a top element. Can't figure out how to access it to replace. It shows they are both 3500 Watt elements.
I guess the question is, is the top element replaceable and how do you get to it?
Thanks.
  • 67 Answers
The top element is in the same position where your electrical come in..it is just under the thermostat also there is a special wrench for removal of element...dont forget to turn of the power and shut off the water and release the pressure from the tank..
Posted on Aug 12, 2010
What is the part # for a Rheem 308 71 model heating element needed?
Any generic element will work.
Match wattage with current element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#parts
Rheem wants folks to buy parts from them... so Rheem tries to convince people that Rheem electric water heaters require special parts.
This is not true... ordinary generic parts will function fine on Rheem.
Gene
Oct 14, 2014 | Water Heaters
I have a Rheem model 71-308. It only has a lower access panel. How do I access the upper heating element?
If your heater only has one access panel, then it only has one element. These are mostly in the 30 gal. electric models.
Oct 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water from my Rheem 72-40-1, I replaced the bottom element a couple of times now in the last 4 months. I replaced the bottom element last night and for the first time opened the top cover to see...
Open following link to look at thermostat wiring
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
If you have dual element electric water heater, then that is a 240Volt water heater.
http://waterheatertimer.org/240-v-water-heater-circuit.html
If you are replacing lower element several times, are you also cleaning out the tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Are you installing same wattage element shown on label on side of tank: Should be 4500Watts.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
If upper element burns out, then tank will have no hot water:
http://waterheatertimer.org/How-it-works.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 83xr52-2 50 gal residential water heater. Water temp was low. I cut power at electric panel, removed upper panel on water heater, turned up thermostat, replaced panel and switched power back on at...
You can open the top up again. I would not turn the temp higher than 130 degrees, maximum. However, there should be above the thermostat a red button. This is where the power wires connect to the thermostats and heating elements. Sometimes this button needs to be reset, press it and discern if you hear a click sound. This means that the high temperature safety switch has tripped open and you had to manually "reset" it. There are two thermostats by the way. The water heater usually works this way. There are two thermostats and two heaters. The upper tank heater turns on first and it heats the top half of the tank. Then when the thermostat above is satisfied it then allows the bottom heater to come on and heat the bottom half of the tank. You might want to set the bottom heater thermostat as well. This is made this way because it is actually faster and more efficient to heat the top half first and the bottom half secondly. Try this first with the reset button. We could check voltages, but that requires a level of knowledge and safety that I am not sure that you are comfortable with. Pictures of the upper and lower thermostats and connections will help if the "reset" does not do the trick. By the way, not meaning or implying anything, but did you move the thermostat in the right direction? Sometimes the dials can be confusing.
Nov 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
Shut off electric current from the breaker switch to Rheem electric water heater for the summer on May 2, 2010 since no hot water needed for the summer. In an attempt to turn on the breaker switch to the...
hi, might want check the thermostat switch, and the heating element. the heating might rusted out, if water wasn't drain out over summer thanks.
Sep 28, 2010 | Rheem Water Heaters
My water is not hot
There are two access panels on the heater, remove screws to access it. They cover the upper thermostat and element and the bottom covers the bottom thermostat and element.
The top thermostat is the main one that has a reset button along with a dial to turn up the heat for the top element. A white plastic knob that you can use a flat head screw driver to turn to adjust.
Also you have one on the bottom to turn to adjust the heat on the bottom.
This is how you adjust thermostat's to increase to a hotter setting.
Jun 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a rheem water heater model # 72- 40- 1 not getting enough hot water .it only has 1 element how can i put in another element and wire it correctly? please help
First, let me say that no Rheem electric water heater that I am aware of has only 1 element.
You may have to search - but there should be one about 8 inches from the top and another behind a panel about 10 inches above the bottom. Please search again.
It is NOT possible to add an element to a "used" water heater. The inner and outer liners must both be sealed and that is done at the factory.
Feb 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
183 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
